Old 12-01-2015, 10:37 AM   #1
els7x5
Drives: Black FR-S
Getting different advice from every shop I talk to.
I just bought the D3PE kit and I am in no rush to get it installed but I am trying to do my research and I get a different answer to almost every question I ask from each shop. What I want is to know what I need to buy in order to safely run this kit at about 300whp with at most 7-8lbs boost. I know things need to get tapped like the oil pan which I am not willing to do myself so I would like to have the tap done professionally or if reasonable the whole kit.
One tuner that I got recommended to me on this site said stock injectors are a safer bet as they won't push things too far (I am paraphrasing) so I will just need the boost controller, afr, and of course the tuning. He is partnered with RevWorks and does a lot of work on these vehicles so with no incentive for making money off me in a shop I am inclined to believe him.
Then I call another shop to see about install and they said $1500 and that I will need new injectors and fuel pump at minimum. Who is right? That price sounds insane considering it is a bolt on kit. Can someone please tell me what I need exactly? What is a reasonable price for this install? I don't mind waiting and saving but I don't want to get screwed over.
P.S. It is the kit that was just sold on here (http://www.ft86club.com/forums/showthread.php?t=97941) and I live in the Orlando FL area.
els7x5 is offline   Reply With Quote
Old 12-01-2015, 11:06 AM   #2
mrk1
Drives: Sterling BRZ Ltd
Your getting different answers but there are parts that are needed and parts that are a good idea. Stock injectors can be fine as long as they are not maxed out, your tuner will tell you this. A upgraded drop in fuel pump is a easy and cheap enough upgrade for some piece of mind. An electronic boost control solenoid is nice because it can be tied into fail safes in EcuTek. AFR gauge is always nice to monitor if you know what your looking at, other wise it can be more trouble then its worth.
1-1500 sounds about right for the install. When installing a used kit have a experienced shop do the work, chances are there are some little things missing.
The Build Thread
GT28RS - eBoost2 - 3.91 Final Drive - Supra LSD
mrk1 is offline   Reply With Quote
The Following User Says Thank You to mrk1 For This Useful Post:
uRBAN_Metal (12-02-2015)
Old 12-01-2015, 12:18 PM   #3
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Pay attention to James, he's extremely knowledgeable in the platform, one of the best if not the best tuner for the car.
To run 300 WHP, stock fueling system is absolutely fine.
FWIW, KAB customs in Sunrise FL charges somewhere around 500-1000 for install.
Old 12-01-2015, 01:14 PM   #4
els7x5
Drives: Black FR-S
Haha you figured that out fast. Yeah I am for sure going with him. Just looked up KAB, they're a bit out of town for me to drive to but SpeedZone Performance quoted me at 800$ for the install, which is reasonable based on all else I have heard and read. They did recommend the injectors but also said that we can do an oil drain line without welding or drilling into my oil pan which I far prefer.
Old 12-01-2015, 06:37 PM   #5
Ken@PTuning
Drives: '92 Nissan 240sx KA-T
Send a message via AIM to Ken@PTuning
The stock fuel pump is more than capable for your power goals.
Ken@PTuning is offline   Reply With Quote
Old 12-01-2015, 06:43 PM   #6
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
That is obviously James @ HRI Tuning, and I would trust everything that he says. The initial turbo kits all came with larger aftermarket injectors and fuel pumps, but a lot of people were running E85 and pushing the limits of the motors which does require those parts. If you are content with 93 octane and 300 whp, then stick with a great tune, stock injectors, and stock fuel pump.
The Following User Says Thank You to King Tut For This Useful Post:
Deep Six (12-01-2015)
Old 12-02-2015, 01:24 AM   #7
els7x5
Drives: Black FR-S
Awesome guys. Thank you for the advice. That is exactly what James said. Now to just decide if I will self install or take it somewhere.
Body Shop issues, need advice. Inextirpable CANADA 14 08-15-2013 12:00 PM
Moving to central NJ, shop advice? Sixstringtrooper NY / NJ / CT / PA 9 07-08-2013 10:32 PM
Talk me into, or out of, a Mac Chimpo Off-Topic Lounge [WARNING: NO POLITICS] 49 06-18-2013 01:37 PM
BMW talk RaceR Other Vehicles & General Automotive Discussions 101 01-15-2013 11:32 AM
Need Tint Shop advice in New Orleans Roborat Southeast 0 07-31-2012 07:30 PM
