Old 11-30-2015, 06:48 PM   #1
brz Islander
sway bar problems =(
So as the topic suggest i have a sway bar/LCA/end link problem. I have whiteline adjustable rear sway and end link. I have ISC LCA's. When i have the end link in the medium configuration i should be able to match it up with the center hole on the sway bar, only i cant. it will only go in the front one. I do not know if this is a problem with the sway bar and lca not being compatible, even though it would seem weird since its literally just a straight LCA. Ive broken 2 endlinks this year, along with the fact they squeak alot. i had this install professionally. i just need help really. i have no idea where to start and how to access the problem.
brz Islander is offline   Reply With Quote
FS: Koni shocks, TRD sway bar & WRX sway bar scirocco78 Brakes, Suspension, Chassis 14 08-31-2015 06:47 AM
WTB: Rear sway end links or sway bar with endlinks JoeBoxer Want-To-Buy Requests 1 08-03-2015 01:20 PM
AT problems? AJPG Engine, Exhaust, Transmission 8 03-08-2015 06:50 AM
Say no to SWAY with our Anti-Sway Bar and Sway Bar Bushing Special. FRSport.com Brakes, Suspension, Chassis 0 01-23-2015 12:38 PM
Transmission problems, oil leaks and detonation problems.. turboviper Issues | Warranty | Recalls / TSB 4 06-18-2014 04:01 PM
