Drives: 2013 FR-S Hot Lava
Wheel Directory: Avid.1 AV-06 18x9.5 +38
Figured I would make a thread about the wheels I decided on going with because no such thread existed.
![]() I decided on going with the Avid.1 AV-06 (TE37 Reps) in Hyper Black 18x9.5 +38 offset square setup. I threw on a set of Hankook Ventus V12 EVO2 tires sized at 245/35/18. I believe this is a design of the wheel and not my tire choice but the lip of the wheel does extend past the tire so be prepared to get paint chips from hitting pretty much anything on the roadway given the fact that these are cheap low pressure cast wheels. (~$600 range wheels) These are heavy wheels ~24 lbs...if you plan on hitting the track on a daily basis with your 86 then these are not the wheels for you. ![]() No rubbing issues up front or in the rear and wheels can turn to full lock with no problem at stock ride height. I do believe that you will have to go on coils in order to lower the car and be able to clear up front however. |
Thanks! Looks good!
More pics please. Profile, up front to see poke, and to see the tire fitment. |
A few more pics as requested
Drives: 2015 FRS
I could kiss u
Been waiting on someone to post I just got these in black How do u like |
Drives: 2014 GT86
Avatar is still with stock wheels though
Haha Avatar is from the day I bought the car...don't think I will change it. You can check my garage for updated pics as I add to her.
As for the wheels I am pleased with them but if you do go with a 18x9.5 square setup you need to really do your research about how to lower the vehicle while avoiding issues rubbing up front. This is what I am running into at the moment. |
Drives: 2013 Fr-s
Did you just slap on the wheels ? are you on stock springs and etc?
I'm interested in getting wheels 18x8 and doing 245/40 all around. but i was told i should do coilovers first before i buy wheels? |
All depends on the offset, going 18x8 will give you some play room and if you do have an issue rubbing up front you can always throw a 3-5mm spacer on there to give you extra clearance.
Drives: FRs WhiteOut
I was looking into these same wheels but in 17x8. But I can't find the weight anywhere. I did find one spot where it said 21 lbs but I kinda want to know if that weight is true. Hopefully somebody can help me out.
#10 |
sounds about right, most reps are in the 19-21 pound range for 17 inch wheels.
#11 |
Drives: 2013 FR-S MT Hot Lava
I found a guy on CL that's selling them(17") to me tomorrow for $450. The Bolt pattern is 5x114.3 though,so I have to get converters. Anyone else have to use lug converters and could you tell me how much that effects the offset?
I figured for the price that I'm getting them for,and I can get the converters from Amazon for about $100,it's worth it. |
#12 | |
Not Bаnned Anymore
Drives: Heavily Modified FRS
#13 | |
#14 | |
Drives: 2020 Subaru BRZ Limited
| Wheel Directory: Volk Racing TE37 18x9.0 +45 Front / 18x9.5 +40 | OmegaKnight | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 4 | 05-03-2016 08:09 AM |
| Wheel Directory: Avant Garde M240 18x9+30/18x9+20 | NyC Zn6 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 9 | 08-07-2015 03:24 PM |
| Wheel Directory: Avid.1-20 17x9 +35 | The Racers Line | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 10 | 07-06-2015 06:26 PM |
| Wheel Directory: Work Meister S1 3-Pc 18x9.5 +29 / 18x9.5 +24 | PradiG | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 48 | 12-12-2013 03:15 AM |
| Wheel Directory: Volk Racing TE37 18x9.0 +45 / 18x9.5 +45 | DarrenDriven | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 0 | 09-04-2012 12:25 PM |
