Old 11-23-2015, 10:04 AM   #1
rosol16
Not A Member
rosol16's Avatar
Drives: 2014 Mustang GT
How much power?
How much power can you safely make on the FA20? Sorry if there is already a topic on this a quick search brought up nothing
rosol16 is offline   Reply With Quote
Old 11-23-2015, 10:06 AM   #2
NotSoJDM
NotSoJDM's Avatar
Drives: '13 BRZ | '04 E55
Anytime you increase power you are decreasing the safety margin of your engine. 320whp and below is all I would be willing to push my stock motor at with a good tune.
NotSoJDM is offline   Reply With Quote
Old 11-23-2015, 10:08 AM   #3
rosol16
Not A Member
rosol16's Avatar
I'm actually looking at the Jackson supercharger kit but with slightly less power maybe 250whp? Granted I know when you increase power you lose reliability but that's just the name of the game.
Old 11-23-2015, 10:21 AM   #4
NotSoJDM
NotSoJDM's Avatar
With a good tune, the JRSC setup will be plenty reliable on stock engine.
The Following 2 Users Say Thank You to NotSoJDM For This Useful Post:
CSG Mike (11-23-2015), rosol16 (11-23-2015)
Old 11-23-2015, 10:42 AM   #5
rosol16
Not A Member
rosol16's Avatar
I know this will definitely void my warranty and really don't want to be building another engine so Ill just make sure to get a good tune.
Old 11-23-2015, 11:16 AM   #6
Anthony
Weight Nazi
Anthony's Avatar
Drives: 13 FRS -399lb, 11 335is, 05 Tiburon
Go with HRI Tuning.
@Sportsguy83
Build Thread | The Venus Project | Any car which holds together for a whole race is too heavy.
Anthony is offline   Reply With Quote
The Following 3 Users Say Thank You to Anthony For This Useful Post:
BlueDubbinTDI (11-23-2015), NotSoJDM (11-23-2015), Sportsguy83 (11-23-2015)
Old 11-23-2015, 01:53 PM   #7
toeout
I'm more curious about the drivetrain. OE clutch will give up and that's not a problem. What about transmission and diff? How long will they sustain 300 whp from a supercharger?
toeout is offline   Reply With Quote
Old 11-23-2015, 01:55 PM   #8
BlueDubbinTDI
BlueDubbinTDI's Avatar
Drives: 2013 FR-S, 2012 MCS
Pretty sure it's hard to overdue it on the stock fuel system so I wouldn't worry too much if you have a good tuner.
Old 11-23-2015, 01:59 PM   #9
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
Just don't cut corners!
MS, CSCS, TSAC-F, CPT
Old 11-23-2015, 02:03 PM   #10
raven1231
200hp
The Following 3 Users Say Thank You to raven1231 For This Useful Post:
86kahl (11-27-2015), LOLS2K (11-23-2015), Ultramaroon (11-23-2015)
Old 11-23-2015, 02:05 PM   #11
LOLS2K
/scion
LOLS2K's Avatar
Drives: '13 86 M/T
200hp
To the crank
LOLS2K is offline   Reply With Quote
The Following User Says Thank You to LOLS2K For This Useful Post:
raven1231 (11-23-2015)
Old 11-23-2015, 02:08 PM   #12
xxscaxx
Drives: 2013 SWP BRZ
There is no answer. Some have popped on stock power. There are others holding 500whp. Seems like its just luck of the draw.
I was on an innovate SC making 280-290 (estimate) for about a year. I upgraded to a JDL Turbo kit with a gtx2867r and now make 442whp/346wtq, all on the stock motor. I even accidentally overboosted on my first tune before i switched and got a dyno tune a few times and so far my motor has been holding strong, no knock, etc. It could blow tomorrow for all I know. Then again, a stock motor could blow tomorrow too.
The only thing you should be concerned with is the risk vs. reward and if you are willing to accept the fact the motor may break, and if you are willing to spend the money to fix it or rather run it stock and have it covered by the dealer (which could vary as well).
Transmission doesn't like 350whp+.
xxscaxx is offline   Reply With Quote
Old 11-23-2015, 03:17 PM   #13
G-awesome
Drives: 2015 Firestorm Scion FRS
G-awesome is offline   Reply With Quote
The Following User Says Thank You to G-awesome For This Useful Post:
neutral (11-29-2015)
Old 11-23-2015, 03:22 PM   #14
rosol16
Not A Member
rosol16's Avatar
Well gotta pay to play a clutch is no big deal I'd run with the stock one until it goes then go with a stronger one. The rear end I just hope that it doesn't go. The motor I can rebuild I've built a few already including the one in my SRT4. I've actually built it twice but the second time it broke was from an original part not one I replaced.
Just a little more power...? magicchef BRZ First-Gen (2012+) — General Topics 1 03-05-2015 10:55 PM
***Blitz Advance Power Air Cleaner and SUS Power Core Intakes*** FT-86 SpeedFactory Engine, Exhaust, Transmission 1 10-07-2013 09:40 PM
What is your prediction on FT86 power and Subaru 086a power? 86Fan Scion FR-S / Toyota 86 GT86 General Forum 88 08-26-2013 11:49 PM
More power with Agency Power vividracing Engine, Exhaust, Bolt-Ons 0 07-26-2013 04:27 PM
