Old 11-23-2015, 01:08 AM   #1
SATX-FT86
Drives: 2015 Raven F-RS (08 CBR600RR) (
help winjet
I just need a few suggestions. I just installed winjet headlights. Well passenger side head light won't turn and now my passenger sidemarker light won't work. Why? Led DRL turn on, blinkers work fine so does the led strip on the bottom foglight. It's just the headlamp and side markers that don't work any suggestions pls
SATX-FT86 is offline   Reply With Quote
Old 11-23-2015, 08:54 AM   #2
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
Bulb is probably out. And your side marker could be loose.
MS, CSCS, TSAC-F, CPT
Old 11-23-2015, 09:40 AM   #3
Cole
Not a troll
Cole's Avatar
It's also possible that a pin on the headlight harness became unseated during the install. If some functions of the headlight are working and others aren't, its most likely a loose connection somewhere, or as @weederr33 said, you just got a bad bulb from the factory.
Also, pictures would help here. Just to verify that everything is in fact hooked up, all connections are properly seated, etc.
Old 11-24-2015, 06:55 AM   #4
SATX-FT86
Ok I'll check as soon as possible. I have it parked right now using my corolla for commute. I've also read on here to check the fuse. I'll start with that and work my way towards the bulb. I'll post up some picture if the fuse is ok thanks guys
Old 11-24-2015, 11:09 AM   #5
weederr33
weederr33's Avatar
If it ends up working, I'll just drive down there and unwire it for more hassle.
Old 11-24-2015, 12:12 PM   #6
SATX-FT86
Well here was the issue. So when I plugged in the male and female I crossed the red and black wire what a Everthing is working fine now . As for the side marker still under investigation
Old 11-24-2015, 12:22 PM   #7
SATX-FT86
thank you for some advice it's good to know there are still people out there willing to help. BTW YOUR CAR IS $ICK I rred your whole thread on mods. Thanks man
Old 11-24-2015, 12:42 PM   #8
Cole
Not a troll
Cole's Avatar
Try switching your bulbs from side to side. Could be as simple as a burnt out bulb. And again, just to reiterate, make sure everything has a solid connection
Old 11-24-2015, 01:06 PM   #9
SATX-FT86
Ok, thanks cole will do. I'll keep ya updated
Old 11-24-2015, 02:06 PM   #10
weederr33
weederr33's Avatar
Thanks! Just trying to make it look like the euro model haha
Old 11-26-2015, 01:09 PM   #11
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
Are your sidemarker bulbs LEDs?
Old 12-05-2015, 08:37 PM   #12
SATX-FT86
nope there stock
[QUOTE=FRSBRZGT86FAN;2463293]Are your sidemarker bulbs led
nope stock. looking into buying new ones
Old 12-05-2015, 09:56 PM   #13
FRSBRZGT86FAN
[quote=SATX-FT86;2471215]
Just interested because I've had LEDs randomly not work for the first time then all of a sudden start working perfectly the rest of the life. If you're looking for sidemarker leds get them from Diode dynamics they are awesome.
DIY: Winjet DRL Always-on l0aded DIY (Do-It-Yourself) Guides 5 04-03-2016 06:41 PM
WINJET DRL MOD Help FRSBRZGT86FAN Cosmetic Modification (Interior/Exterior/Lighting) 0 09-17-2015 08:54 PM
WINJET HID'S 5AD86D Cosmetic Modification (Interior/Exterior/Lighting) 1 03-26-2015 09:50 PM
WTT: Winjet Black Headlight for Winjet chrome dezmoondo Exterior Parts (Aero, Lighting, Etc.) 0 04-13-2014 03:02 AM
Custom Purple Winjet and Black Winjet Headlights xclusive_brett Cosmetic Modification (Interior/Exterior/Lighting) 35 12-17-2013 08:28 AM
