Old 11-17-2015, 11:44 AM   #1
nickmerronesucks
Ned flanders
nickmerronesucks's Avatar
Drives: 13 BRZ, 16 Hellcat, 22 Ram 2500
Am I hurting performance?
I have a Speed by design Kit, The downpipe is 2.5 I believe. I have a 3 inch over pipe, I have a invidia front pipe which appears to be about 2 inches maybe 2 and a 1/4, and a 3 inch hks catback...That front pipe does anyone think could be hurting me performance wise? Debating on buying a 3 inch front pipe just so everythings the same size.
797Performance.com
nickmerronesucks is offline   Reply With Quote
Old 11-17-2015, 11:45 AM   #2
Dream20b
Y u do dis?
No doubt, When you go bigger, it will work better, just get tuned for it.
Dat Hot Lava Doe
Clearly you have no clue what you are talking about. Everything you said was completely and utterly the ramblings of a babbling idiot regurgitating garbage from his mouth. Everyone here is now dumber from reading your post. Please die now.
Dream20b is offline   Reply With Quote
The Following User Says Thank You to Dream20b For This Useful Post:
Freeman (11-17-2015)
Old 11-17-2015, 12:09 PM   #3
mrk1
Drives: Sterling BRZ Ltd
Larger will flow better but its the most advantageous to have the larger pipe up front where the gas's are hottest. The small down pipe will be your first restriction.
My turbo car has a 3" down pipe and then 2.5 the rest of the way back. Im not seeking big HP so this works fine, the SBD turbo isnt very big so a nice 2.5" setup should do just fine.
The Build Thread
GT28RS - eBoost2 - 3.91 Final Drive - Supra LSD
mrk1 is offline   Reply With Quote
all season high performance or winter performance tires? Aloxi NY / NJ / CT / PA 29 03-24-2015 09:23 PM
Excelerate Performance: Your Northeast Performance and Installation Center ExcelerateRep NY / NJ / CT / PA 40 07-22-2014 05:55 PM
Jellybeans hurting our cars :( Minovsky CANADA 20 04-29-2014 05:41 PM
how much drop without hurting handling? nonicname Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 11-19-2012 08:23 PM
