Old 11-16-2015, 10:36 AM   #1
Toyota86.ir
Mike Tune HKS E85 FD 4.88
Drives: Toyota GT86 AT NA Stage 2
similar WOT AFR/Timing but different Acceleration?!!
you can see two log files of my car:
Mod: EL Header + Front pipe + catback
fuel: pump gas
first log file is 3 hours after ecu flash :
http://datazap.me/u/toyota86ir/amir-...data=6-8-12-30
second log file is after 600 miles driving :
in both log files all parameters like WOT timing WOT afr are similar (minor difference) but the car acceleration and feeling in the first run is far better than second run.
why acceleration is different when all parameters are similar?
Toyota86.ir is offline   Reply With Quote
Timing Cover Oil Leak AllDayJonRay Issues | Warranty | Recalls / TSB 18 06-06-2016 03:12 AM
Ignition Timing and AFR JB86'd Software Tuning 15 03-16-2015 11:23 AM
oil leak at timing cover choi0706 Issues | Warranty | Recalls / TSB 8 09-10-2014 06:25 PM
How much timing are you running on your FI?!? Fear Forced Induction 4 06-09-2014 02:28 AM
E85, Boost and Ignition Timing jamesm Software Tuning 23 12-11-2013 02:19 PM
