Old 11-11-2015, 08:53 AM   #1
SillySaxon
SillySaxon's Avatar
Drives: Sc10n Series FR-S
Zeitronix ECA errors
Hi guys.
So I did a DIY on my own Flex Fuel kit. I used the Zeitronix ECA and the GM FF sensor in the engine bay.
I have checked all of my connections and made sure it's properly grounded, but on pump 93 it's reading 37% E content which is almost certainly completely wrong.
How can I go about locating the source of this error. From what I can tell on the zeitronix site, this is equaling about 1.7 volts on the output line.
I figure as long as you smile while driving the car, you're doing it right.
SillySaxon is offline   Reply With Quote
Old 11-11-2015, 01:45 PM   #2
SillySaxon
SillySaxon's Avatar
So Zeitronix says make sure I'm not using the return fuel line.
But I have no idea which one that is, can't seem to find a flow chart.
I used the one closest to the firewall (rear of car)
Does anyone know which lines are which?
THanks
Old 11-11-2015, 01:53 PM   #3
DeliciousTuning
PhoneFlash by EcuTeK
DeliciousTuning's Avatar
THanks
It actually doesn't matter if you use the feed or return line, or even the port or DI feed line. Additionally, the Continental ethanol sensor is omnidirectional and it does not matter which way the fuel flows through it. This is almost certainly a faulty ECA.
If you don't want the headache, there's always this one
www.delicioustuning.com/flexfuel
Sincerely,
Zach
Old 11-11-2015, 01:58 PM   #4
LOLS2K
/scion
LOLS2K's Avatar
Drives: '13 86 M/T
Hi guys.
Can you elaborate on how you wired it all up. Thanks.
LOLS2K is offline   Reply With Quote
Old 11-11-2015, 06:08 PM   #5
SillySaxon
SillySaxon's Avatar
Ok, green from ECA to white on contintental/gm
Orange from ECA and pink/black from continental to a red wire connecting to 10A seat heater fuse
Brown from ECA and Black from continental to black wire connecting to ground point.
Blue from ECA to PIN 21 on ECU
Old 11-11-2015, 06:09 PM   #6
SillySaxon
SillySaxon's Avatar
I think it's the sensor. I pulled it out of the fuel line and powered it on with just air, reads 25%
If it's telling me my fuel is 37% then it's probably actually 12% (shit gas) with a 25% off reading....
Old 11-11-2015, 06:39 PM   #7
DeliciousTuning
We've seen a couple Continental sensors fail over the years, and they always read 0% when they do so. :/
Sincerely,
Zach
Old 11-12-2015, 09:31 AM   #8
LOLS2K
/scion
LOLS2K's Avatar
Drives: '13 86 M/T
Bummer, it does seem to be a bad sensor. Please keep the thread updated as you get it all fixed. Good luck.
BTW, where did you purchase the fuel lines?
Old 11-12-2015, 01:02 PM   #9
SillySaxon
SillySaxon's Avatar
Summit racing. I'm working on a writeup, but once it's not fucked up I"ll post it.
I have a new FF sensor on the way from a gauranteed working brand new parts seller in the US, won't take a month from China and if it's fucked up I can talk to them.
I will note that I spoke with Zeitronix via email and they were more helpful than they needed to be. They could have said "bad ff sensor, sorry" but the guy reviewed my install and had my troubleshoot, so huge props to them.
Old 11-12-2015, 01:05 PM   #10
LOLS2K
/scion
LOLS2K's Avatar
Drives: '13 86 M/T
Zeitronix is top notch. No Chinese toy gauges, just honest "does what it's supposed to" gauges. Thanks, looking forward to your write up.
Old 11-12-2015, 05:00 PM   #11
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
THanks
Just FYI for future reference, our car does not have a return line, our fuel system is "returnless"
Old 11-12-2015, 05:01 PM   #12
LOLS2K
/scion
LOLS2K's Avatar
Drives: '13 86 M/T
Did you build your own fuel lines as well?
Old 11-12-2015, 05:02 PM   #13
Sportsguy83
Drives: Limited BRZ
What do you mean?
Old 11-12-2015, 05:03 PM   #14
LOLS2K
/scion
LOLS2K's Avatar
Drives: '13 86 M/T
What do you mean?
I vaguely recall you DIYing your flex fuel kit instead of buying of the shelf.
FS: Unichip w/ download cable, Zeitronix ethanol content analyzer Ashikabi Engine, Exhaust, Bolt-Ons 27 03-06-2015 09:18 PM
Errors while logging FirestormFRS Software Tuning 6 02-06-2015 01:58 PM
Linking Errors Michael Site Announcements / Questions / Issues 0 05-12-2014 05:55 PM
Zeitronix Ethanol Content Analyzer - E85! No Limit Motorsport Engine, Exhaust, Bolt-Ons 7 05-03-2013 03:04 PM
