Old 11-10-2015, 06:28 PM   #1
golemslord
Drives: 2014 White FRS
Will these foglights fit/work?
http://www.ebay.ca/itm/251529590830?...%3AMEBIDX%3AIT
golemslord is offline   Reply With Quote
Old 11-10-2015, 06:39 PM   #2
8R6
8R6's Avatar
Drives: FRS
it should
8R6 is offline   Reply With Quote
Old 11-10-2015, 09:09 PM   #3
justin6280
justin6280's Avatar
Drives: 2015 FRS
yeah, I have the exact one on my car
justin6280 is offline   Reply With Quote
Old 11-10-2015, 09:10 PM   #4
Packofcrows
hey you, yeah you <3
Packofcrows's Avatar
Drives: 2014 37J FR-S
are they glass>?
Packofcrows is online now   Reply With Quote
Old 11-10-2015, 09:33 PM   #5
MuseChaser
Feeling like thinking....
MuseChaser's Avatar
Polycarbonate lenses, but very strong; the lights themselves are pretty high quality, at least in look and feel. I just put a set in my car, although I got the clear ones instead of yellow. The bezels fit a little looser than the stock bezels, and I like the look of the gloss black even less than I thought I was going to like it, but I'm sure they'll get less glossy after a few thousand miles of road grit. If not, I might just take some scotchbrite or very fine sandpaper to them and make'em matte myself. The bezels fit fine, though; plenty secure.
A word on the spring steel "U-clips" or whatever they're called that placed over the mounting holes in the bumper to accept the two screws for each light. The few youboob install videos I saw show folks installing them wrong, then complaining that they don't fit. They don't press in from the side; if you look at the clips, you'll see a cut out in the middle of the folded part. You'll also see a protrusion on the bumper (facing up on the top screw, and down on the bottom screw) that extends into that space to lock the clip in exactly the right spot. It takes a little coercion to get the clips on, but once you have'em in the right spot they're plenty secure and the screws line up great.
The harness is of decent quality, but as noted many other places, there are NO directions. On the other hand, it's pretty hard to screw up. The only problem so far is figuring out where exactly to connect the switch power wire. Although I have the harness routed and zip-tied into place, I haven't made any of the actual connections yet; I want to attach the switch power wire to the same connection that powers the low beams so the fogs only work when the low beams are activated, as fog lights are supposed to work. No one seems to be able to pinpoint that yet. If I'm the first, I'll let everyone else know.
Yes, I'm happy w/ the quality, and the price is more than right. I wish the bezels were matte instead of gloss, and of higher quality like the OEM bezels, but that's my only gripe.
Hope that helps.
Barry
MuseChaser is offline   Reply With Quote
Old 11-10-2015, 11:14 PM   #6
mizzta21
mizzta21's Avatar
Drives: 2014 whiteout, scion fr-s
Originally Posted by golemslord View Post
yes, i have this exact kit
mizzta21 is offline   Reply With Quote
Old 11-14-2015, 11:32 AM   #7
Rossi
Drives: Toyota 86
Little of topic, will H7 bulbs work for the fogs?
Rossi is offline   Reply With Quote
FS: FRS foglights whitefrs Exterior Parts (Aero, Lighting, Etc.) 11 04-28-2014 04:36 PM
Does anyone in the US with an FR-S have Foglights??? pituala Cosmetic Modification (Interior/Exterior/Lighting) 42 01-30-2014 11:15 AM
WORK Emotion Wheels ** Winter Promotion || Free WORK Lugs or WORK Caps ** RavSpec Wheels and Tires 18 12-10-2013 05:19 PM
No foglights possible? losjackal Cosmetic Modification (Interior/Exterior/Lighting) 7 06-17-2013 09:13 PM
