Old 11-09-2015, 04:13 PM   #1
Spartarus
...Just add nauseum
Spartarus's Avatar
Drives: 2003 (AP1) S2000
Delete. Fixed issue.
Delete. Fixed.
There are many ways to displace.
-Spartarus
Spartarus is offline   Reply With Quote
Old 11-09-2015, 06:42 PM   #2
steve99
Intake air leak of exhaust leak will cause high fuel trims and incorrect afr in closed loop if fuel trims are way off then these incorrect rims will be applied in open loop assuming is not a hybrid speed density tune
Old 11-09-2015, 06:50 PM   #3
Spartarus
...Just add nauseum
Spartarus's Avatar
Thanks. Checked for leaks thoroughly, as I was having other issues with the tune on startup. No leaks. I fixed the startup issue by fixing the "MAF correction after start (neutral)" tables. Only 2 idle modes were screwed up. It would idle fine then "click" to a different idle mode and shoot up to 1700 RPM.
Also, on the datalog I posted, AFR deviates from commanded AFR even when the STFT and LTFT read zero. The car runs very rich (off the chart rich) under WOT.
Playing with MAF scaling is bringing it closer.
I'll have it back on the dyno next weekend for a little tuning session. I can only collect so much data driving around on the street. It's getting better.
-Spartarus
Maf Scaling VGI Tool Phantobe Software Tuning 14 04-30-2019 04:55 PM
MAF scaling, showing you what i cam up with trdric Software Tuning 24 06-29-2017 01:10 PM
Windows and scaling MAF Darkparadox911 Southern California 0 06-16-2015 08:45 PM
What MAF scaling says about your intake BuBlake Software Tuning 27 12-09-2014 06:01 AM
BRZEdit MAP scaling jamesm Software Tuning 13 10-02-2013 01:43 PM
