Old 11-04-2015, 05:20 PM   #1
itisthumper
itisthumper's Avatar
Drives: WRB BRZ MT
Playing certain files on my USB stick causes head unit to restart
Ive seen others have issues on this problem and suggesting resolutions. Unfortunately, they havent worked for me but Ive discovered some things while troubleshooting.
Ive used a 128gb PNY stick for a year now, with hundreds of files, with no issues. A couple days ago, I loaded three more files (40-100mb each; long DJ mixes) and I started experience problems.
Mix 1 plays just fine
Mix 2 take a while to load (30 sec) but plays eventually but it causes my head unit to restart at times
Mix 3 takes even longer to load, and when plays, is sometimes missing the track info (artist, title, etc.) and causes my head unit to restart at times (more often than mix 2)
I tried this on two different brand USB sticks with the same issue; though on one stick, it took far less time to load the files. I reformatted one of them to FAT32 and reloaded the files with the same issue. I also tried moving the files to different folders but got the same issue.
Could it be corrupted files? They both play flawlessly on my computers. These are the only files that are causing issues. I'm thinking of re-encoding them and trying it again. This is driving me nuts...
itisthumper is offline   Reply With Quote
Old 11-04-2015, 05:45 PM   #2
Chanpion
Drives: 13 FRS Satin
Try mp3 and split them into shorter mixes.
Chanpion is offline   Reply With Quote
The Following User Says Thank You to Chanpion For This Useful Post:
itisthumper (11-05-2015)
Old 11-04-2015, 06:16 PM   #3
humfrz
It just doesn't like THAT music .........
humfrz - ma med time .....
soulreapersteve (11-04-2015)
Old 11-04-2015, 06:38 PM   #4
soulreapersteve
Contract? /人◕ ‿‿ ◕人\
soulreapersteve's Avatar
Perhaps the mixes are too long and the headunit can't read file sizes up to a certain limit? I haven't read up much on the specifications of the HU on both cars since I simply use auxiliary cable or bluetooth.
Pretty sure its in the manual somewhere, but I'm too lazy to find it.
The Twins make me smile
Old 11-04-2015, 07:09 PM   #5
DJCarbine
Thupercharged
DJCarbine's Avatar
What is the encoding for the mp3/flac files?
I had some issues with reading mp3s and I just re-encoded them and they worked fine
2013 FRS
Vortech V3 11psi
Old 11-05-2015, 02:48 PM   #6
itisthumper
Drives: WRB BRZ MT
I will give that a try later
I have larger files that play just fine
It's a 320kbps CBR MP3
SOLD Wolfdogelite Audio/Visual, Electronics, Infotainment, NAV 9 02-05-2016 08:37 PM
FS: Like new OEM BRZ head unit w/ nav inositle Audio/Visual, Electronics, Infotainment, NAV 2 08-26-2015 08:38 PM
Anybody know ... what head unit this is? chaoskaze Electronics | Audio | NAV | Infotainment 3 12-21-2014 06:44 PM
need help with playing music through shead unit??? sci3 Electronics | Audio | NAV | Infotainment 0 09-18-2014 12:34 AM
head unit in GTA excited86 Electronics | Audio | NAV | Infotainment 1 06-18-2012 07:42 PM
