Old 11-04-2015, 05:49 PM   #1
Carnewbee
Drives: Black 86 gts
Lowering springs and wheels
Ok so want to put 17-9 on front and 17-10 on back and lower it with lowering springs giving it an inch drop. Question it will wheels fit, and will I need to get camber arms etc to fix camber or will it be fine as is after wheel alignment? Haven't played with suspension or anything before. Thanks
Carnewbee is offline   Reply With Quote
Old 11-04-2015, 05:51 PM   #2
MisterSheep
Killed Scion
MisterSheep's Avatar
Drives: 2013 FR-S Whiteout
why do you want 10 wide in the back?
I know that 17x9 +38 will fit just fine lowered with a camber bolt up front.
or if you want to run 17x9 +42 with like a 3-5mm spacer would be fine too. But I do not know what would be good for a 10 wide.
Instagram: trevor.parque
Old 11-04-2015, 05:54 PM   #3
D_Thissen
D_Thissen's Avatar
Does anyone make a wheel in a 17x10?
Old 11-04-2015, 05:57 PM   #4
Carnewbee
I just like the fat wheels behind. Yeap enkei rpf1 17x10 +18
Old 11-04-2015, 05:59 PM   #5
Carnewbee
What about 17x8.5 +30 at front and 17x9.5 +18 at back? Need camber adjustment?
Old 11-04-2015, 05:59 PM   #6
MisterSheep
Killed Scion
Will you be running the RPF1's?
Old 11-04-2015, 06:00 PM   #7
Carnewbee
Yeah was planning on it
Old 11-04-2015, 06:06 PM   #8
MisterSheep
Killed Scion
17x9.5 +18 would probably poke out. Try running a 17x9.5 +38
Old 11-04-2015, 06:08 PM   #9
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Drives: Heavily Modified FRS
I think tires that wide are such a waste of $$$ but its yours so do what you will haha
Old 11-04-2015, 06:10 PM   #10
Carnewbee
Ok just found a place with deal on 17x8.5+30 and 17x9.5+18 as a package. If I get the rear guards rolled would that sort poke or do I have to see if I can convince them to give me 9.5+ 38?
Old 11-04-2015, 06:14 PM   #11
MisterSheep
Killed Scion
Any possible chance I can confince you to go squared?
Old 11-04-2015, 06:16 PM   #12
Carnewbee
Squared as in same all round?
Old 11-04-2015, 06:18 PM   #13
MisterSheep
Killed Scion
Yes. I know a 9.5 +38 fits all around.
Old 11-04-2015, 06:21 PM   #14
See question 5 and suspension sub category.
http://www.ft86club.com/forums/showthread.php?t=96158
JohnJuan (11-15-2015), Sarlacc (11-04-2015)
TRD Lowering Springs aaguilar3 Northern California 39 11-08-2017 08:16 PM
TRD Lowering Springs and 16" wheels anyone have? stevesnj Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 08-07-2016 09:22 PM
TRD Lowering Springs? Jrryjms07 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 16 04-04-2014 12:49 AM
TRD Lowering Springs? kALMIGHTY Suspension | Chassis | Brakes -- Sponsored by 949 Racing 12 04-29-2013 11:10 AM
Lowering springs HELP FRS_13 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 9 10-27-2012 11:03 PM
