Old 11-03-2015, 01:36 PM   #1
automatic
Drives: WRB BRZ
Trailer Hitch Mounting Locations?
I'm looking to get a trailer hitch and there are 2 types that I'm looking at.
Type 1: Attach to frame rails underneath car
Type 2: Attach to Bumper bar
Both are rated for 200/2000lbs.
What are the pros and cons for each mounting option?
In a rear end collision, which mounting option will cause more damage?
If I want to remove the hitch a few years from now, will option 2 make it more difficult since the exposed bolt on the other side of the bumper beam rust out?
Is the mounting point for Type 2 against the frame or is it still considered a "bumper"?
Looks like type 1 is held by the clamping force of the 4 bolts, and if it exceeds the clamping force will be held by the bolts themselves.
Type 2 is held by 4 bolts and 2 nuts and the pulling force is totally on the nuts/bolts.
They are both approximately the same price....but Type 2 takes longer to install...not that it makes too much of a difference. I just want to get the "better" design.
automatic is offline   Reply With Quote
Old 11-03-2015, 06:37 PM   #2
churchx
churchx's Avatar
Drives: 2014 GT86
I recall reading in manual that this car is NOT for towing. (even if toyota had listed tow hook among installable options for unknown reasons. Or maybe they list for all the cars, just forgot to remove for this? I don't know what to think when i saw also snow-chains listed among options as our cars with their ground clearance are certainly for tackling some serious offroad in snow deeper then 15", right? ). Also no matter how towing heavy trailer may affect clutch hardly meant for that (i burnt on previous car of mine when towing slightly heavier car of friend to service shop. Not completely, but fact is that clutch slippage started few months after that), i also recall when learning for license, that car weight also should be within reasonable limits to towed trailer mass for safety, and toyobaru twins are rather light, not some big SUV. Are you sure you want to go through with that?
Old 11-03-2015, 07:07 PM   #3
GeorgeJFrick
GeorgeJFrick's Avatar
Drives: 2013 Subaru BRZ Limited LR
There are plenty of people who tow all the time with the twins. Seriously it's not a big deal if you aren't going over the listed rate for the car/trailer.
Yo: [ame="https://www.youtube.com/watch?v=_DFJG24EAWo"]We Get Hitched! - Scion FR-S Track Build - EP11 - Final Episode - YouTube[/ame]
GeorgeJFrick is offline   Reply With Quote
The Following User Says Thank You to GeorgeJFrick For This Useful Post:
wparsons (11-04-2015)
Old 11-03-2015, 07:10 PM   #4
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Drives: Heavily Modified FRS
Just no :/ I would never tow with my twin I rather buy a shitty truck and tow with that.
Old 11-03-2015, 07:36 PM   #5
churchx
churchx's Avatar
Drives: 2014 GT86
Listed rate for car? LOL, citing manual:
233 page, 2-5. Driving information, Trailer towing
"Toyota does not recommend towing a trailer with your vehicle. Toyota also does not recommend the installation of a tow hitch or the use of a tow hitch carrier for a wheelchair, scooter, bicycle, etc. Your Toyota is not designed for trailer towing or for the use of tow hitch mounted carriers."
So that's your official towing rating by manufacturer . Those plenty that still tow with twins are doing that on their own risk. Never heard of traffic cops checking it here, but i doubt that in case of accident insurance investigation will pass that by, even if you wasn't at fault, due driving unsafe setup. After all, one point of traffic rules here list also that it's not allowed to tow something above manufacturer's stated tow rating. I guess that's AND, not OR with other limits like 750kg, or no heavier then vehicle's weight.
Old 11-03-2015, 07:37 PM   #6
bmxr
bmxr's Avatar
Drives: 2017 BRZ PP WR Blue
Either one will work fine as long as you abide by the manufacturers' stated limits. Which one weighs more? I'd guess the first one. I'd go with the second.
For me, a good general guideline for towing with a car not designed for towing, is not to exceed 50% of the GVW of the car, just to be safe. Obviously you can go way beyond that with a Super Duty, but staying under 1200-1800lbs with a passenger car seems very reasonable. Towing race wheels and tools, one watercraft or street bike, or even a couple dirt bikes has never been a problem for me. Obviously, you should be more careful about stopping distances etc., but if you are, it won't hurt your clutch or brakes.
Personally, I have towed with ALL my cars with absolutely ZERO problems, including Mustangs, GTI, WRX, and RSX-S; mostly motorcycles.
bmxr is offline   Reply With Quote
Old 11-03-2015, 08:41 PM   #7
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
In my personal opinion I'll go with the tow bolt location, it's easily installed/removable.
As long as your not towing cars or bigger you'll be fine.
Old 11-04-2015, 10:19 AM   #8
automatic
Drives: WRB BRZ
Thanks for your input everyone. I'll be towing a light trailer and my dirtbike and since both hitch locations are "ok" I'll just pick the cheaper/easier to install one.
The Following User Says Thank You to automatic For This Useful Post:
LOLS2K (11-04-2015)
Old 11-04-2015, 10:22 AM   #9
LOLS2K
/scion
LOLS2K's Avatar
Drives: '13 86 M/T
Post up some pictures when you get hitched.
LOLS2K is offline   Reply With Quote
Old 11-04-2015, 11:46 AM   #10
IPGJames
Drives: ...Cars...
That Slambert one is perfect..makes me want to get one just to tow something..ease of use is awesome with that
IPGJames is offline   Reply With Quote
Old 11-04-2015, 01:56 PM   #11
cjd
cjd's Avatar
Drives: 2017 BRZ
Being able to tow a tire trailer without a 30lb weight penalty is awesome. It's also out of stock still... Or I'm always missing out... I'd also love to be able to haul sheet goods from the lumber yard occasionally...
Old 11-07-2015, 03:24 AM   #12
Hyper4mance2k
Alexandrino_Auto
Hyper4mance2k's Avatar
Drives: series.Blue
I drove from LD to DC in August with a Slambert trailer hitch and a 1000 lb trailer.
The Shadetree Project: I turn wrenches
Hyper4mance2k is offline   Reply With Quote
The Following User Says Thank You to Hyper4mance2k For This Useful Post:
Busybee (09-29-2019)
Old 03-21-2019, 02:16 PM   #13
KoreanJesus
No one special
Drives: 2018 BRZ tS
Issue hosting image...
I ride my scooter towing this trailer. Longest distance to date was from Central Texas to Foley, AL. I couldn't even tell it was back there.
Yakima Rack'n'Roll 78"
Yakima Skybox 21
Trailer weighs 150lbs
HD shocks for increased payload
I can fit all of my fishing & camping gear, several changes of clothes, and still have room for dumb souvenirs I pick up along the way for friends.
KoreanJesus is offline   Reply With Quote
Old 03-27-2019, 05:36 PM   #14
Qwimby1
Drives: 14 FRS Monogram, 05 Mazdasped Miata
They had them in stock last week. Mine arrived today.
Qwimby1 is offline   Reply With Quote
The Following User Says Thank You to Qwimby1 For This Useful Post:
cjd (03-28-2019)
Trailer Hitch Jack Black Tracking / Autocross / HPDE / Drifting 31 12-22-2015 08:26 PM
Twin Hitch - FRS/BRZ Trailer Hitch Slambert Miscellaneous 2 10-07-2014 01:34 PM
BRZ Trailer Hitch - New in Box Coop07 Exterior Parts (Aero, Lighting, Etc.) 3 06-20-2014 06:15 PM
GoPro Mounting Locations Jericon Electronics | Audio | NAV | Infotainment 10 02-05-2014 12:24 PM
