Old 10-30-2015, 06:02 PM   #1
MattHoffman
Drives: BRZ Limited
4bar map
Will a n/a brz run with a omni 4bar? I have oft stg2 e85 tune now and just got a 4bar with a supercharger I bought, seeing how electronics can be sensitive, I wanted to test the sensor before I installed the entire kit and be stuck removing it if the sensor is damaged. I attached the 4bar and the car tried but wouldn't start. I tried twice before placing the stock m.a.p. back and the car runs fine. Any info will be helpful.
MattHoffman is offline   Reply With Quote
Old 10-30-2015, 06:04 PM   #2
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Drives: Heavily Modified FRS
I think it wil but you will need to tune it.
DustinS (10-30-2015)
Old 10-30-2015, 06:07 PM   #3
Kodename47
Kodename47's Avatar
Drives: UK GT86
It needs to be configured otherwise it won't work.
.: Stealth 86 :.
Kodename 47 DJ:
Old 10-30-2015, 06:08 PM   #4
DustinS
DustinS's Avatar
Drives: 2013 Ultramarine FR-S
Car will need to be tuned for the MAP sensor. Which is an expensive check. Might as well just get the tune done for supercharger and check from there. I wouldn't assume it (the map sensor) would die so quickly though.
DustinS is offline   Reply With Quote
Old 10-30-2015, 06:13 PM   #5
Kodename47
Kodename47's Avatar
Drives: UK GT86
He has OFT, you just need to change the MAP settings, don't forget to change the CEL limits too.
.: Stealth 86 :.
Kodename 47 DJ:
The Following User Says Thank You to Kodename47 For This Useful Post:
MattHoffman (11-10-2015)
Old 10-30-2015, 06:16 PM   #6
mrk1
Drives: Sterling BRZ Ltd
Will not run with a 4 BAR unless the tune is for that sensor
The Build Thread
GT28RS - eBoost2 - 3.91 Final Drive - Supra LSD
mrk1 is offline   Reply With Quote
The Following User Says Thank You to mrk1 For This Useful Post:
Old 10-30-2015, 09:31 PM   #7
steve99
As other guys said car wont start if you change to different MAP sensor, you need to change MAP sensor scaling to suit in tune to suit new map sensor
I thought the OFT supercharger tunes used 2.5bar omni but not 100%
would not go driving car unless tune is redone for alternate map sensor.
their are some MAP sensor scaling in this thread (even though ite primarily for maf sensor)
http://www.ft86club.com/forums/showthread.php?t=64790
4bar map sensor 85$(sold) tjsmooth25 Engine, Exhaust, Bolt-Ons 0 12-04-2014 01:28 PM
