Looking to buy 18 inch Rims.. Fitment question
Hi guys, I'm looking on putting on some 18 inch rims. I really like the Blue Series rims but of course there just 17s. Im looking to go with a flush look just like the blue series. I've narrowed it down to the Ambit RE02 which are very similar but the question is what exact size should I get in 18s so it looks flush like the blue series? Thanks for the help.
Drives: 2013 Subaru BRZ Limited (Black)
You'll see i've posted a question about the RE02 as well today! I do believe that the RE02's only come in one size of 18s (18x9.5 + 38). So, does that answer your question?
#3 | ||
Not Bаnned Anymore
Drives: Heavily Modified FRS
http://www.ft86club.com/forums/showthread.php?t=25177 http://www.ft86club.com/forums/showthread.php?t=7535 Go check those out guys. |
#4 | |
Senior Misanthrope
I don't know much about the Ambits, but I do know that the RE02 is a replica of the Enkei RS05RR. It's way cheaper than the Enkei, but I don't know how robust or reliable the Ambits will be. |
18x9.5+38 spec wheels will poke just a little up front and require some camber to fit if lowered.
Old photo of our car when we had the same spec Enkei RS05RR wheels.
#6 | |
Would coilovers be necessary for the extra clearance? |
Drives: 2013 Brz C38 (bought not built :P)
Ray's te57 extremes might be something to consider, they aren't the cheapest thing on the planet but I believe the look fits what you are after. Can't help for size though, unless you want me to take pics of how they look on mine (18x9.5).
Oem replacement springs or lowering springs? think if they are same height you will be good but if lowering springs you will need to adjust camber in order for the to fit (could be wrong) maybe someone else can chime in with more detailed info
#9 | |
Drives: 2005 Toyota Camry
-alex |
#10 | |
However, if you go with camber plates you would not have that issue. |
#11 | ||
No rice, no life
Drives: 2013 Asphalt FR-S
I already had KW coilovers before installing the wheels so I'm not sure about clearance with the oem springs.
2013 Asphalt Scion FR-S | Jackson Racing Supercharger | KW V3 | Enkei RS05RR 18x9.5
#12 | |
It's also possible that we stated that because we could not confirm at the the time for you. |
#13 |
#14 |
Drives: 86 GTS
Question from someone with no experience in cars, how do you camber? Why bother if you can fit a smaller wheel or don't lower it.
| gt 86 stock 16 inch rims | yo joshman | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 30 | 08-26-2015 02:29 PM |
| Wtb: 5x100 16 inch rims | san101 | Canada Classifieds | 0 | 07-16-2015 08:42 PM |
| 15 or 16 inch rims | EZWood | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 9 | 09-30-2014 01:58 PM |
| 245/35-18 on 8.5 inch Rims | DSLeach | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 5 | 06-09-2014 01:30 AM |
| 19 inch rims too big? | Liquidcell | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 18 | 09-03-2012 01:07 PM |
