Old 10-22-2015, 09:50 AM   #1
DrDuquette
DrDuquette's Avatar
Drives: 2013 Premium White, 2006 TL
When too much is too much (camber)
I just put on my new wheels. 17x9 and now notice the camber. Only 3/4 of the tire touches the ground. Looks like the same amount of tire that touched with the 215. Haa has. Name:  ImageUploadedByTapatalk1445518216.665870.jpg
Size:  302.3 KBI'm at maybe 3 degrees. The car just doesn't feel as planted as I would expect running the new wheel setup over stock. Is this amount of camber hurting me on the street? Where is a good degree? I think I have gone past the point of diminishing returns....
DrDuquette is offline   Reply With Quote
Old 10-22-2015, 10:00 AM   #2
adamg
Drives: brz
looks like 4/5 tire touching to me
adamg is offline   Reply With Quote
The Following User Says Thank You to adamg For This Useful Post:
SlammedSilly (10-22-2015)
Old 10-22-2015, 10:13 AM   #3
jvincent
jvincent's Avatar
3 degrees in the rear is a lot for just street duty.
If you look at the track threads you'll see most of the recommendations are less than that.
Old 10-22-2015, 10:31 AM   #4
DrDuquette
DrDuquette's Avatar
Yes. I can't count. My bad.
Old 10-22-2015, 10:58 AM   #5
GSpeed
GSpeed's Avatar
Drives: 2015 BRZ
For street use, yeah, 3° static is a little much. Especially in the rear where you have a not-crappy camber curve.
GSpeed is offline   Reply With Quote
Old 10-22-2015, 11:15 AM   #6
MisterSheep
Killed Scion
MisterSheep's Avatar
Drives: 2013 FR-S Whiteout
I was expecting a
one of these kind of threads.
Instagram: trevor.parque
The Following 5 Users Say Thank You to MisterSheep For This Useful Post:
8R6 (10-22-2015), Cop (11-30-2015), CxG (10-25-2015), GotBRZ1691 (10-23-2015), Pat.Thornton (10-24-2015)
Old 10-22-2015, 11:17 AM   #7
vroom4
2 in front 1 in back for someone not autox or traxk day.
vroom4 is offline   Reply With Quote
The Following 3 Users Say Thank You to vroom4 For This Useful Post:
CxG (10-25-2015), DrDuquette (10-22-2015), MisterSheep (10-22-2015)
Old 10-22-2015, 11:53 AM   #8
ajcarson11
Drives: 2013 Subaru BRZ Limited (Black)
I run 2deg on street in front and rear. Just depends on your needs and how much money/effort you want to put into correcting it. If you can dial it in, I agree with @vroom4
ajcarson11 is offline   Reply With Quote
The Following User Says Thank You to ajcarson11 For This Useful Post:
Old 10-22-2015, 12:38 PM   #9
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Is this perception because the car has a tendency to not stay straight on some roads? It may be caused by your tires + the increased camber, causing tramlining.
-alex
The Following User Says Thank You to mav1178 For This Useful Post:
Old 10-22-2015, 01:11 PM   #10
Kuri
Kuri's Avatar
Drives: 2014 BRZ Limited SWP
-3 Daily :O
#TrackDayBro
Kuri is offline   Reply With Quote
The Following User Says Thank You to Kuri For This Useful Post:
kingkenny (10-22-2015)
Old 10-22-2015, 02:01 PM   #11
DrDuquette
DrDuquette's Avatar
I was expecting a
How does that tire hold air??!!
Old 10-22-2015, 02:03 PM   #12
DrDuquette
DrDuquette's Avatar
Thanks. The good thing is that did spend the money up front to have front camber plates and the rear LCA adjustment. Just need to spend some time under the car this weekend.
Old 10-22-2015, 02:04 PM   #13
HatchirokuV2.0
Drives: 2013 FRS
From what I've been reading and what I've seen on many FR-S'/BRZ's, anything past -2* in the rear is just too much for street/autocross duty. I'd run the fronts at -2* and keep the rear at -1.7*, depending on your suspension setup and whether you have aftermarket sway bars and endlinks.
EDIT: It may take two-three alignments to find the perfect balance for your car and driving habits/expectations out of the car.
HatchirokuV2.0 is offline   Reply With Quote
The Following 2 Users Say Thank You to HatchirokuV2.0 For This Useful Post:
DrDuquette (10-22-2015), Kuri (10-22-2015)
Old 10-22-2015, 06:53 PM   #14
8R6
8R6's Avatar
Drives: FRS
i run -2.7 in the rear cuz i dont have adjustable lower arms lol. but im also lowered 2"
8R6 is offline   Reply With Quote
The Following 2 Users Say Thank You to 8R6 For This Useful Post:
DrDuquette (10-22-2015), MisterSheep (10-23-2015)
FS: Smoked Colins tails - PRICE DROP Jas1137 Canada Classifieds 25 11-02-2018 08:26 AM
*FREE alignment* with Purchase and install of Front Camber / SPL Rear Camber Arms! Corner3garage Southern California 188 04-24-2015 02:10 PM
*FREE alignment* When you get Front Camber Bolts and Rear Camber Arms Installed! Corner3garage Mechanical Maintenance and Tools 6 10-31-2013 04:40 PM
