Old 10-19-2015, 10:26 AM   #1
mcbrawr
Drives: 2014 BRZ Limited
Bayson R Front Lip problems
I'm trying to install my front lip but the ends of it are overlapping the push tabs inside the front fenders. Everything underneath has lined up. Help?
mcbrawr is offline   Reply With Quote
Old 10-19-2015, 01:07 PM   #2
meWant
Drives: '16 BRZ Limited
I'm assuming that it is the sti style front lip, mine does the same but I just left it without using the push tabs. Seems to be holding up fine although I believe the push tabs are supposed to go through the holes on the lip there to hold it in place
meWant is offline   Reply With Quote
Old 10-19-2015, 01:16 PM   #3
vividracing
vividracing's Avatar
Unfortunately, with any replica aero parts, you are going to run into fitment issues (however mild or major they may be). If you aren't satisfied with that part, you could always try exchanging for another and hope for better fitment.
vividracing is offline   Reply With Quote
Old 10-19-2015, 01:38 PM   #4
mcbrawr
Just to clarify -- I'm talking about the push tabs located directly in front of the wheels inside the fender. The push tab locations underneath the car ( near the skid plate ) line up perfectly. The fitment over all is great I just can't seem to figure out how the sides need to be connected without blocking those two push tabs on both sides.
The Following User Says Thank You to mcbrawr For This Useful Post:
meWant (10-20-2015)
Old 10-19-2015, 01:51 PM   #5
LOLS2K
/scion
LOLS2K's Avatar
Drives: '13 86 M/T
Can you upload any pictures?
LOLS2K is offline   Reply With Quote
Old 10-19-2015, 03:25 PM   #6
mcbrawr
Will do ASAP. Might be tomorrow, though.
Old 10-19-2015, 03:27 PM   #7
LOLS2K
/scion
LOLS2K's Avatar
Drives: '13 86 M/T
@mcbrawr It'll be easier to help you out. Thanks in advance.
Old 10-19-2015, 04:57 PM   #8
kbye
kbye's Avatar
Drives: 2014 FR-S
I have this lip, there shouldn't be any overlap. The lowest plastic clip in the fender liner should line up with the hole in the lip. There should be a supplied clip that replaces the OEM one to accommodate the additional thickness of the lip.
This may sound like a dumb question but have you tried flipping the lip around? I had weird fitment issues until I realized that my lip was upside down.
kbye is offline   Reply With Quote
The Following User Says Thank You to kbye For This Useful Post:
meWant (10-20-2015)
Old 10-19-2015, 06:04 PM   #9
Packofcrows
hey you, yeah you <3
Packofcrows's Avatar
Drives: 2014 37J FR-S
Remember 3M.
Packofcrows is offline   Reply With Quote
Old 10-20-2015, 02:57 AM   #10
meWant
Right, sorry for not clarifying but I figured you were talking about the ones at the front wheel wells at the end of the front bumpers.
I just kind of let mine hang there too although BaysonR does supply extra push tabs, like another commentor had said, which allows you to replace the push tab so it fits the lip and fender liner.
Old 10-20-2015, 09:20 AM   #11
mcbrawr
I received no clip...
Old 10-20-2015, 02:07 PM   #12
mcbrawr
Here's pics. any help is appreciated
http://imgur.com/a/qq2f4
Old 10-20-2015, 05:36 PM   #13
BRZoomTX
BRZoomTX's Avatar
Drives: '13 BRZ
It intends for you to take that clip out, then use two screws to hold everything together. Did that on mine and it works fine.
'13 WRB BRZ ~470whp // Instagram // YouTube
BRZoomTX is offline   Reply With Quote
Old 10-20-2015, 07:04 PM   #14
mcbrawr
As in remove the two push tabs located there normally? Please excuse my hesitation, I want to be sure before I drill into my car lol
Bayson R front lip experience? Husker BRZ Cosmetic Modification (Interior/Exterior/Lighting) 21 04-18-2017 12:02 PM
New FR-S TRD ABS Front Bumper Lip Bayson - $140 shipped STS-V Exterior Parts (Aero, Lighting, Etc.) 11 03-14-2017 10:00 PM
Bayson R TRD Style T Front Bumper Lip in ABS - Sold out for months and twice $? STS-V Cosmetic Modification (Interior/Exterior/Lighting) 10 07-29-2014 03:33 AM
brz bayson r rep front lip?! DAN_BRZ Canada Classifieds 11 06-05-2014 03:42 PM
Bayson R polyurethane BRZ front lip (SF east bay) serial gixxer Exterior Parts (Aero, Lighting, Etc.) 1 08-27-2013 02:27 AM
