Old 10-13-2015, 04:58 PM   #1
cornel45
Drives: 2013 Scion FRS
310HP/ 320TQ Aluminum 4 cyl Ecoboost swap
I want to eventually do an engine swap to my FR-S and have been looking into different options and I stumbled across the Ford Ecoboost 2.3 as a very compact, light alternative to the common LS swap. This is the engine found on the new Mustangs and they come with a 6 speed manual transmission. It is an all aluminum inline 4 engine that makes around 300 lb/ft of torque at only 2000 RPM. It propels the 3600lb mustang to 60 in 5.4 seconds and quarter mile in the 13's in stock form. They respond very well to basic intake/exhaust/tune mods and the aftermarket will be very strong for them because of their use in mustangs.
I think this would be a very ideal engine swap for the FRS because of the lightweight aluminum engine, small packaging and huge power gains. Also, fuel economy should not suffer very much if at all, judging by the EPA estimates for the much heavier mustang with the 2.3 engine.
There are going to be tons of these in junk yards pretty soon and I'd imagine they will be cheap compared to the 5.0 coyote engines.
I'd like to hear everyone's input on this engine swap as well as reasons why this would be a bad idea.
Here is a link to the engine I am talking about: http://www.full-race.com/articles/Mu...Drivetrain.php
cornel45 is offline   Reply With Quote
Old 10-13-2015, 05:13 PM   #2
Alltezza
Alltezza's Avatar
Drives: WRB Limited BRZ
Why dont you just drop a turbo in your FA20 and have the same power if not more than the 4 cylinder mustang?
Or is this just a project that youre interested in?
Alltezza is offline   Reply With Quote
The Following 3 Users Say Thank You to Alltezza For This Useful Post:
Dream20b (10-19-2015), Porcupint (10-13-2015), Summerwolf (11-04-2015)
Old 10-13-2015, 05:19 PM   #3
Porcupint
Drives: 13 GBS BRZ
I'm with this guy^ drop a smallish turbo on your FA20 and go to a slightly taller final drive.
Porcupint is offline   Reply With Quote
Old 10-13-2015, 05:24 PM   #4
continuecrushing
continuecrushing's Avatar
Drives: 2013 Firestorm FRS
so much win.
next thread:
What suspension(or exhaust/wheels/turbo etc) is best for my car? Plz help
The Following 6 Users Say Thank You to continuecrushing For This Useful Post:
CrispyCheddar (10-20-2015), drewbot (10-14-2015), GotBRZ1691 (10-13-2015), IBill4You (10-15-2015), raven1231 (10-13-2015), shifter907 (10-13-2015)
Old 10-13-2015, 05:28 PM   #5
jawn
jawn's Avatar
Drives: 2015 CWP BRZ Limited
Anything is possible if you throw enough money at the problem.
Every engine swap has 3 major hurdles to overcome, once you have enough money:
1. Clearance - is there enough space for the new motor and transmission? An inline 4 obviously isn't as wide as the FA20, but it certainly is a lot taller. Does the new transmission fit the current transmission tunnel?
2. Mounts - once everything is more or less the correct size and shape, you're probably going to need all new engine mounts and transmission mounts.
3. Programming and Wiring - will the Ford ECU play nicely with your gauges, traction control, ABS, sensors, etc...? Will you be retrofitting a Ford gauge cluster?
Obviously, you have other costs like routing exhausts, and sourcing a custom-length driveshaft, but these are easier problems to deal with.
If you don't think you can handle all of these things on your own, you're going to be paying a shop a good chunk of change to figure out all of these things, and you can easily spend into 5 figures getting everything to work.
More often than not, you're going to find that it'll be easier and cheaper to go forced induction on the factory motor. Basically every available turbo kit will get you to or above the 300WHP mark, and they start at $3K.
jawn is offline   Reply With Quote
The Following User Says Thank You to jawn For This Useful Post:
86 South Africa (11-04-2015)
Old 10-13-2015, 05:29 PM   #6
cornel45
Main reason I wanted a swap vs a turbo is because from what I've read on here, the reliability is just not there. I remember reading about a guy that blew his motor at 280whp, which is what the Ford 2.3 is at from the factory. Also, the manual transmissions in these cars don't handle too much power. Lastly, a motor that was designed from the start to be turbo'd with 300+ HP and Torque and with lower compression and stronger internals will be much more reliable than one that isn't.
I guess what I want is a responsive engine that is also reliable and a transmission that is designed to handle the power. Being an aluminum 4 cylinder inline engine, it should also be lighter than the FA20.
Incidentally the transmission that comes with the 2.3 L Ecoboost engine is the same as the one on the 5.0 Coyote, so it can handle more power easily.
The Following 2 Users Say Thank You to cornel45 For This Useful Post:
cf6mech (11-05-2015), raven1231 (10-13-2015)
Old 10-13-2015, 05:59 PM   #7
fang_gt86
FR Noob
fang_gt86's Avatar
First of all, why do you want this build? Race car/track? DD or just simply because of "Look, I got a very unique FR-S"? My wild guesstimate is that it won't be cheap. That means $10k if you do half of the work yourself, $20k if someone else do it. Anything can be done with a lot of $$$.
Why not just do a fully build Fa20 + a high quality kit for the same amount of HP and reliability for the same amount of $?
"I'm having too much fun to care about horsepower" - Unknown
6MT FR-S Whiteout:OFT- OTS V2 Stage 2 (93oct & E85), Tomei UEL, Invidia OP, JDL UltraQuiet FP, Ark Grip catback, GS hood struts, Perrin Inlet & K&N drop-in
fang_gt86 is offline   Reply With Quote
The Following User Says Thank You to fang_gt86 For This Useful Post:
Old 10-13-2015, 06:05 PM   #8
Chad11491
Drives: 85.5 Porsche 944, '15 mustang GT PP
You make a lot of good points, but one blown motor does not = unreliable. Check out 86atlanta on Facebook. Our local tuner Doug at DBW has done a very large % of the FI twins in Ga, and runs a 3800 installed, tuned, out the door price on the sbd turbo kit. It will put you right around the 300hp mark. I can't recommend him enough.
Chad11491 is offline   Reply With Quote
Old 10-13-2015, 06:18 PM   #9
cornel45
I want this build because I enjoy driving a more powerful car. Maybe I'm just used to more power, some of my previous cars were NA1 and NA2 S2000's, '04 CTS-V, '02 Lexus IS300 with LS3/T56 swap, 93 Supra TT 6 speed, and 92 Acura NSX 5 speed. I appreciate the way the FR-S feels probably more than any other car I've driven, but would like about 100hp more. I think it would be a perfect car at that point. I've had 500hp cars and that's not what I want. I think 300-350 crank hp is plenty for this car, I just want it to be reliable.
I know it won't be cheap. That's OK with me. I will be doing much of the work myself and 10k would be doable.
As far as a quality turbo build for the FA20, that won't be cheap either. At the end of the day I would still have an engine that wasn't designed for boost mated to a transmission that is a ticking timebomb. I could probably sell my low mileage engine and transmission for $3000 to offset the price of the swap and be at about the same price as building the FA20.
Old 10-13-2015, 06:22 PM   #10
cornel45
I did not know that.
Thank you. I'll definately check it out on Facebook.
The Following User Says Thank You to cornel45 For This Useful Post:
Old 10-13-2015, 07:59 PM   #11
GotBRZ1691
GotBRZ1691's Avatar
Drives: 2014 Subaru BRZ Limited 6smt
I wouldn't spend the time or the money for a 2.3L Ecoboost.
Turbo on a FA20 is all about the quality of the tune and managing the heat. Like mentioned above turbos can be had for ~$4,000 for the power range you are looking to get to.
If you want to do a budget swap, this is the route I would go:
http://www.ft86club.com/forums/showthread.php?t=94724
GotBRZ1691 is offline   Reply With Quote
Old 10-13-2015, 08:09 PM   #12
raven1231
Holy hell that's a good deal!
Old 10-13-2015, 08:16 PM   #13
industrial
Add lightness!
industrial's Avatar
Drives: 17' WRX
Or you could just get a supercharger. Don't know why you need or want a turbo with so many good supercharger options for this car that'll get you to 220-380whp rather easily.
If you are really considering a motor swap for the reasons you stated, you'd be looking into a fa20dit not this ford thing.
industrial is offline   Reply With Quote
Old 10-13-2015, 08:29 PM   #14
GotBRZ1691
GotBRZ1691's Avatar
Valid point.
OP if your only looking for another ~100 -~150 HPs then supercharge it. Too many options to remember them all.
Jackson Racing
Innovate / Sprintex
Kraftwerks
Harrop
EdleBrock
HKS
Vortech
to name a few...
rented an ecoboost stang then test drove a BRZ perryair FR-S / BRZ vs.... 16 06-22-2015 06:17 PM
mustang ecoboost or gt86? coyot FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 7 05-02-2015 11:39 PM
2015 Mustang Ecoboost vs Scion FRS ashtray FR-S / BRZ vs.... 37 01-25-2015 01:58 PM
Explorer EcoBoost gets low marks Exage Other Vehicles & General Automotive Discussions 4 08-30-2011 07:52 PM
