Old 10-06-2015, 09:54 PM   #1
gmanvilla1@gmail.com
gmanvilla1@gmail.com's Avatar
Drives: FRS
CR2P Wheels
Is anyone running stancenation CR2P wheels: Front 18x8.5 +40 Rear 18x9.5 +40. Is this a good fit with springs?
gmanvilla1@gmail.com is offline   Reply With Quote
Old 10-06-2015, 09:58 PM   #2
TylerLieberman
TylerLieberman's Avatar
Drives: '24 GR86
Stancenation makes wheels now?
Fuck.
TylerLieberman is offline   Reply With Quote
Old 10-06-2015, 10:01 PM   #3
MisterSheep
Killed Scion
MisterSheep's Avatar
Drives: 2013 FR-S Whiteout
I believe stancenation doesn't make wheels.... But I say go for it. It wont look #stancenation without coilovers for that #hellaflush look.
Instagram: trevor.parque
Old 10-06-2015, 10:01 PM   #4
Drives: FRS
Oops I think the actual brand might be work emotion
Old 10-06-2015, 10:09 PM   #5
evomike
Drives: frs
So you are looking for WORK emotion 2 piece wheels
evomike is offline   Reply With Quote
Old 10-06-2015, 10:13 PM   #6
Drives: FRS
Correct.
Old 10-06-2015, 10:30 PM   #7
Drives: FRS
What size tires do you recommend for those size wheels on springs?
Old 10-06-2015, 10:34 PM   #8
MisterSheep
Killed Scion
Depends on the offset.. But since I see you doing 8.5 and 9.5 I'd do 235/35 front and 255/35 rear
Old 10-06-2015, 10:35 PM   #9
Drives: FRS
Offset is +40
Old 10-06-2015, 10:36 PM   #10
TylerLieberman
Drives: '24 GR86
Lol I know, I was just being sarcastic.
There should be quite a few threads of people running similar specs on their cars here on this forum. Even though they aren't the same wheels, they'll provide the same results because they're running the same size and offset.
Typically, I see people with setups like that running something like 225/40 up front and 245/35 or 255/35 in the rear. I personally am not a fan of staggered setups on these cars, and others will tell you the same, as from a "performance" standpoint, it isn't ideal on this car. If it were me, I'd run something like 18x9.5 +40 with 265/35s all around.
Old 10-06-2015, 10:40 PM   #11
Drives: FRS
Thank you. That set up would require coilovers right.
Old 10-06-2015, 10:42 PM   #12
MisterSheep
Killed Scion
That would look widdddde and mean. I can vogue for a non staggered setup. But at the same time I think 265 is too much meat for these cars with stock power.
Old 10-06-2015, 11:37 PM   #13
TylerLieberman
Drives: '24 GR86
I thought the same thing and then I ran it on mine and it was crazy good. Others like @Jive Turkey can vouch for the 265 width squared setup. Of course, tire size only does so much. It also comes down to the compound, suspension, and alignment.
Old 10-07-2015, 12:06 PM   #14
8R6
8R6's Avatar
Drives: FRS
LOL @ "stancenation" name combined with a +40 offset
8R6 is offline   Reply With Quote
Work Emotion CR2P 18'' Celigts Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 02-24-2017 03:22 AM
*Wheels Collection* Winter Package 2015-2016 (Alloy Wheels + Tires) wheelsco Canada Classifieds 4 10-08-2015 03:55 PM
TWS Forged Wheels T66-F - Ultra lightweight Race Wheels with Style // DSG Performance Jason@DSG Wheels and Tires 37 12-17-2014 02:50 PM
Discount Tire installed my wheels and tires...and damaged my wheels...advice needed! stratodyne Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 16 07-17-2013 02:21 PM
Wheels, Wheels, Wheels | Island Import Performance IslandImportPerformance Wheels and Tires 4 07-31-2012 10:08 PM
