Old 10-05-2015, 09:37 AM   #1
Taaato
Drives: Grey Toyota 86
Exclamation Buddyclub Tail Lamp Problem!
Hey guys, first time posting and would appreciate any suggestions on this matter. I recently installed Buddyclub tail lights on my 86 along with the relay that came with it. What followed was the failure of my drls/low beams/high beams/indicators. Dash as well as my tails automatically light up when I start the car and all that's visible on the dash is that the high beams and fog lights are on despite the fact that I don't have either of them on. My guess is it has to do with the relay but I'm not quite sure. Hope you guys can help, thanks!
Taaato is offline   Reply With Quote
Old 10-06-2015, 06:22 AM   #2
elBarto
elBarto's Avatar
Drives: Toyota GT86
Try to switch back to stock flasher relay, if all is well ask for a new one (warrenty) or order the tapturn flasher relay.
send using mind controle
"Oversteer is when your ass hits the wall, Understeer is when your face hits the wall!" - Unknown Stockcar driver
BeNeLux FB group: GT86/BRZ Owners
elBarto is offline   Reply With Quote
Old 10-06-2015, 07:01 AM   #3
Cole
Not a troll
Cole's Avatar
Your BCM is kill. That's going to be an expensive fix at the dealership.
Old 10-06-2015, 11:12 PM   #4
LED86
LED86's Avatar
Drives: Black 86 GTS
I think your friend messaged me on facebook. To me it sounds like one of your fuses is blown. For what reason Im not sure.
I would switch back to stock relay and see if that fixes anything.
If not then check the fuses in the fuse box under the steering wheel/pedal area. Check the back of the cover for the main ones like "tail, fog, DRL etc" pull them out and see if connection is broken. Replace with a suitable new fuse and if it blown again then something is shorting. Check wires on the tail light or any wiring you think may have been changed.
LED86 is offline   Reply With Quote
buddyclub taillights, failure, gt86, issue, relay
Buddyclub tail lights broken LED Joshwahhhs Cosmetic Modification (Interior/Exterior/Lighting) 2 12-04-2015 03:57 AM
Buddyclub LED tail light (Sold) JinH522 Exterior Parts (Aero, Lighting, Etc.) 4 02-28-2015 03:13 PM
WTB Tom's or Buddyclub tail lights! SLOWrz Want-To-Buy Requests 1 02-17-2015 02:58 AM
CRYSTAL LED BLUE TAIL LAMP JPxM0Dz Cosmetic Modification (Interior/Exterior/Lighting) 11 12-17-2014 04:05 AM
>>BuddyClub Tail Lights - Pics and Video<< FT-86 SpeedFactory Cosmetic Modification (Interior/Exterior/Lighting) 0 11-20-2013 12:13 PM
