Old 10-04-2015, 08:54 PM   #1
soundman414
Drives: 2014 Silver BRZ Limited
5th and 6th gear gone.
My 5th and 6th gear appear to be shot. It'll shift fine until it wants to go into 5th or 6th and then just goes to 2k rpm and sends no power to the wheels. Then when speed has fallen enough, it'll downshift to 3rd or 4th depending on throttle position. This is an Auto, FYI.
I really hope Subaru doesn't give me shit about this when I take it in tomorrow. It's a 2014 and only has 18k miles on it. I'll report back tomorrow how my visit goes.
Video of the issue:
soundman414 is offline   Reply With Quote
Old 10-04-2015, 09:00 PM   #2
cdq85
cdq85's Avatar
Drives: 2013 Raven FR-S
Any mods on car?
cdq85 is offline   Reply With Quote
Old 10-04-2015, 09:30 PM   #3
Packofcrows
hey you, yeah you <3
Packofcrows's Avatar
Drives: 2014 37J FR-S
they'll look at your ecu and see if you've red lined it. Also gonna check trac control etc etc... so just make sure you good on that. If so, youll get a new transmission if its bad. If it's clutch, get ready to call Toyota to make it a case. I doubt clutch would only affect 5+6, though. Synchros?
Packofcrows is offline   Reply With Quote
Old 10-04-2015, 09:35 PM   #4
GotBRZ1691
GotBRZ1691's Avatar
Drives: 2014 Subaru BRZ Limited 6smt
Just have the master technician go on a ride along and claim it warranty if you have it and don't have mods that the dealer could blame.
I had my manual transmission replaced without a single hitch
GotBRZ1691 is offline   Reply With Quote
Old 10-04-2015, 09:37 PM   #5
soulreapersteve
Contract? /人◕ ‿‿ ◕人\
soulreapersteve's Avatar
It's an auto :p As far as I know, autos dont have clutch or synchros.
Does this happen in manual mode, by any chance? You shift into 5th and nothing happens?
The Twins make me smile
The Following 2 Users Say Thank You to soulreapersteve For This Useful Post:
humfrz (10-05-2015), Packofcrows (10-04-2015)
Old 10-04-2015, 09:43 PM   #6
Trust86
Drives: 2016 Halo FRS
Sounds like an computer or shift solenoid issue. Or if you serviced the transmission maybe too little or too much transmission fluid? Try and disconnect the battery for 5-10 mins and take it out for a drive again.
Trust86 is offline   Reply With Quote
Old 10-04-2015, 11:02 PM   #7
soundman414
It does happen in manual mode. That's how I figured out it was 5th and 6th gear.
The only mods I have made is rear diff bushings, oil catch can, perrin steering rack lock down and front control braces. I did do rustoleum undercarriage spray, but made sure the tranny was masked off for spray.
The Following User Says Thank You to soundman414 For This Useful Post:
soulreapersteve (10-04-2015)
Old 10-05-2015, 09:35 AM   #8
stevesnj
stevesnj's Avatar
they'll look at your ecu and see if you've red lined it.?
The EDR only records the last 30 seconds of ECU data regarding pre crash conditions. RPM's are not recorded.
My 2016 Build thread
Old 10-05-2015, 06:19 PM   #9
soundman414
Well after 4 hours of the car at the dealership, the tech found nothing wrong and therefore nothing was done. They couldn't replicate the problem and said keep an eye out for the conditions that might surround the next time it comes up. It's tough leaving the dealership knowing that nothing was done and that this could crop up again and if I don't get it to happen in front of a tech... Then nothing is wrong, even with a video.
Old 10-06-2015, 02:01 PM   #10
why?
Only happy when it rains.
why?'s Avatar
Drives: series.blue
Toyota's software records the highest rpm's hit among other things.
Old 10-06-2015, 05:19 PM   #11
Erok
NooB
Erok's Avatar
Drives: 14' FRS Monogram
Or...they fixed the problem but don't want to tell you about it. Manufacturers are kind of funny that way sometimes.
Erok is offline   Reply With Quote
Old 10-07-2015, 04:58 PM   #12
billwot
Drives: '11 Cayman , '14 Camry, '11 Tacoma
Even if that's true, so what?
The mfgr sets the rev limiter at what they have determined to be the max safe limit.
If warranty claims were denied because a car had been "redlined" then nearly 100% of warranty claims would be denied.
billwot is offline   Reply With Quote
Top Gear Crashes Helicopter During Filming of "Top Gear Korea" Episode SteveH Other Vehicles & General Automotive Discussions 7 02-13-2013 12:08 AM
Reverse Gear not going into gear? MT joergasm Issues | Warranty | Recalls / TSB 22 11-29-2012 12:08 AM
No more 1st gear thump or 2nd gear notchiness kc4mne Scion FR-S / Toyota 86 GT86 General Forum 28 09-06-2012 08:39 PM
5th Gear and 6th Gear 0% throttle to 80% throttle gear crunch? kharn83 Issues | Warranty | Recalls / TSB 9 08-06-2012 07:44 PM
Reverse gear on the first and second gear side randytindoggy Scion FR-S / Toyota 86 GT86 General Forum 50 01-29-2012 01:21 PM
