Old 10-02-2015, 10:55 AM   #1
Toyota86.ir
Mike Tune HKS E85 FD 4.88
Drives: Toyota GT86 AT NA Stage 2
Secret
Hi Guys
me and all of my friends believe some days our gt86 is not quick and responsive but non of us know why a car some days has more torque and some days it has less torque ?
we say the cars are like human , some days are unhealthy.
i try to log my ecu for finding the answer .
do you have any idea?
Toyota86.ir is offline   Reply With Quote
Old 10-02-2015, 11:07 AM   #2
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Drives: Heavily Modified FRS
Originally Posted by Toyota86.ir View Post
Hi Guys
Oil Temp is a big part of it along with air intake temps.Just sayin.
Hot oil ECU pulls timing, install oil cooler to fix this issue. Hot AIT means less O2 being pulled into the engine so less fuel can be added and less power will be made. Humidity also plays into this effect as well. Those are just a few things that you have little control over that effect how your car drives.
The Following 2 Users Say Thank You to go_a_way1 For This Useful Post:
aagun (10-02-2015), rjgough95 (10-02-2015)
Old 10-02-2015, 11:07 AM   #3
fang_gt86
FR Noob
fang_gt86's Avatar
Hi Guys
You got to be more specific. What exactly is that "some day"? Sunny and dry? Cold and dry? High humidity? Gas grade and so on..
"I'm having too much fun to care about horsepower" - Unknown
6MT FR-S Whiteout:OFT- OTS V2 Stage 2 (93oct & E85), Tomei UEL, Invidia OP, JDL UltraQuiet FP, Ark Grip catback, GS hood struts, Perrin Inlet & K&N drop-in
fang_gt86 is offline   Reply With Quote
Old 10-02-2015, 11:17 AM   #4
bfrank1972
Drives: 2013 FR-S Argento
1) As others have mentioned, temperature, humidity, gas, etc all make a noticable difference.
2) On top of that, it's also probably you. Human 'butt dynos' are notoriously inconsistent, depending on your mood, how alert you are, etc.
3) Also driving conditions, around town my FR-S feels quite peppy. On the interstate passing, you really notice the power deficit.
4) Driving style, are you driving in the torque dip?
bfrank1972 is offline   Reply With Quote
Old 10-02-2015, 11:55 AM   #5
Toyota86.ir
you are right about condition.
we know gas quality, height from sea level, humidity and temperature make noticable difference.
we know going from one city to another city with different condition as mentioned above make noticable difference and it take some times ecu adjust it.
non of them relate to my question.
i have no idea but i guess the problem come from ecu and the sensors.
Old 10-02-2015, 11:57 AM   #6
Toyota86.ir
i ordered oil cooler because the 0w-20 oil temperature easily goes above 121 celicious in summer.
Old 10-02-2015, 12:15 PM   #7
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Tell me about it hahaha!! Next thing to do would be reduce under hood temps as much as you can to reduce AIT. Also make sure you intake is sealed and pulls only cold air from infront of the bumper.
Old 10-02-2015, 12:22 PM   #8
jawn
jawn's Avatar
Drives: 2015 CWP BRZ Limited
Ideal gas laws and stoichiometry.
jawn is offline   Reply With Quote
The Following User Says Thank You to jawn For This Useful Post:
Toyota86.ir (10-23-2015)
Old 10-02-2015, 01:12 PM   #9
Toyota86.ir
My car use both ethanol and pump gas. When i feel the car is not healthy the ethanol smell increase in car room.
I logged the map but iam was 1 with no ignition timing drop but it seems fuel do not burn correctly.
Afr seems go richer and throttle response is mushy
Old 10-02-2015, 01:14 PM   #10
aagun
Drives: 86
IAM issue or you really have issue
what modal u own ?
aagun is offline   Reply With Quote
Old 10-02-2015, 01:17 PM   #11
Toyota86.ir
Is there any way for reducing under hood temps?
I will check intake leakage , good idea , thanks
Old 10-02-2015, 01:20 PM   #12
aagun
Drives: 86
that is the issue
what modal ur 86 is ? from car ID plate in driver door side
Old 10-02-2015, 01:22 PM   #13
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Vented hood, wrap your headers, make side vents, proper skid plate (beatrush makes one now) ummmm remove the crash bar if you want more flow (I would not do this but its an option) What intake do you have?
Old 10-02-2015, 01:41 PM   #14
Toyota86.ir
what modal u own ?
There is no iam issue, the problem is not unique to brz and all cars have similar problem.
DIY Mini Bar/secret compartment? VakaGT Scion FR-S / Toyota 86 GT86 General Forum 11 01-28-2015 07:16 AM
Secret Weapon-R Intake?? scionfr_s Engine, Exhaust, Transmission 38 11-01-2014 02:35 PM
This has been a secret for far too long TheChopShop Other Vehicles & General Automotive Discussions 4 10-05-2012 02:50 AM
Top Secret / HKS Parts underway R0ME0 Engine, Exhaust, Transmission 37 05-25-2012 10:03 AM
