Old 10-01-2015, 11:38 AM   #1
FrankAR15
Drives: 2013 Genesis Track
Any significant changes from 2013 to 2014?
Just as title asks, any differences or improvements between '13 and '14 FRS?
Sorry I didn't search, at work on my phone, lol
Ok I tried searching 2013 FRS vs. 2014, and 0 matches
FrankAR15 is offline   Reply With Quote
Old 10-01-2015, 12:23 PM   #2
kch
Senior Misanthrope
kch's Avatar
You obviously didn't look very hard.
http://lmgtfy.com/?q=2013+vs+2014+frs&l=1
Old 10-01-2015, 12:28 PM   #3
Knee pads, new HU and most of the TSB changes (seems to be hit and miss what car got what changes though).
That is it.
Old 10-01-2015, 12:28 PM   #4
continuecrushing
continuecrushing's Avatar
Drives: 2013 Firestorm FRS
really? No one else?
Fine, I'll do it.
2014 came with turbo's
Old 10-01-2015, 12:30 PM   #5
Fine, I'll do it.
Old 10-01-2015, 12:32 PM   #6
Muaddib
Mentat
Muaddib's Avatar
Drives: 2013 Scion FRS 6MT
All i noticed was some of parts in the heads have different part number.
Muaddib is offline   Reply With Quote
Old 10-01-2015, 12:33 PM   #7
continuecrushing
because of our dual exhaust, would I need to use 2 of those (1 in each hole)
hehehe
Old 10-01-2015, 12:37 PM   #8
hehehe
Wooooo Twin turbo! Even better.
Old 10-01-2015, 12:38 PM   #9
Rampage
Senior Member/Old Fanboi
Rampage's Avatar
Drives: 2000 2ZZ-GE MR2 Spyder HT
Biggest thing was probably the ECU re-calibration that seems to have cured some on-off throttle detonation issues and improved reliability. That actually took place in later 2013 but all 2014s have it.
So many modders have more cents than sense!
Rampage is offline   Reply With Quote
Old 10-01-2015, 12:42 PM   #10
These would be the TSB changes. All of the new production after each TSB was issued should have had the changed parts, flash, etc. From reading here though it seems that some did not get them at the factory for some bizarre reason. My 14 for example still had the old window trim even though it was past the VIN where the TSB cut off.
Old 10-01-2015, 12:47 PM   #11
FrankAR15
Yeah, I can google search, but I figured this forum would know a little more.
Thanks to all that responded! Trying to research for my sons first car
Old 10-01-2015, 12:52 PM   #12
LOLS2K
/scion
LOLS2K's Avatar
Drives: '13 86 M/T
Is there a huge TSB list somewhere? I have never taken a car into the dealership for TSB work. Can I just take my '13 in and say "Do all the TSB updates"?
LOLS2K is offline   Reply With Quote
Old 10-01-2015, 12:53 PM   #13
Although the 13s and 14s are closing in value you cab still usually find 13s for a bit cheaper. You do have to weigh the reduced cost against the benefits of having a 14 with many of the problems that some of the early 13s had already worked out.
When searching for stuff on here just ignore the site search function (it just plain sucks) and use Google but include ft86club in the search. It will work far better for you.
Old 10-01-2015, 12:55 PM   #14
http://www.ft86club.com/forums/showthread.php?t=21868
Depends on your dealer. Some will still insist that you demonstrate the issue before they will do the TSB. Mine just went through the list and made sure everything was covered (I have a good dealer).
TRD Carbon Fiber Fender Fins Scion FR-S 2013-2014 / Subaru BRZ 2013-2014 RallySport Direct Exterior Parts - Lighting 73 07-31-2015 11:39 AM
Cosworth Stage 1.1-1.3 Power Package BRZ 2013-2014 / FR-S 2013-2014 With Videos! RallySport Direct Engine, Exhaust, Bolt-Ons 104 07-02-2015 10:10 AM
APR Front Bumper Canards Subaru BRZ 2013-2014 / Scion FR-S 2013-2014 RallySport Direct Exterior Parts - The Rest 0 01-14-2014 11:17 AM
GTSpec Rear Subframe Reinforcement Panels Subaru BRZ 2013-2014 / Scion FR-S 2013-2014 RallySport Direct Brakes, Suspension, Chassis 0 01-08-2014 12:32 PM
Injector Dynamics Fuel Injectors 1300cc Subaru BRZ 2013-2014 / Scion FR-S 2013-2014 RallySport Direct Engine, Exhaust, Bolt-Ons 0 01-07-2014 12:13 PM
