Old 09-30-2015, 04:09 AM   #1
La5to
insta: LastoBRZ
Will this tow hook fit on a BRZ?
I'm looking for a tow hook for my BRZ and I want a cheap one just for looks, any idea if this one fits?
http://www.aliexpress.com/item/Folda...2_73_74_75,0_0
La5to is offline   Reply With Quote
Old 09-30-2015, 04:26 AM   #2
Hentai
Hentai's Avatar
Drives: 2015 Halo GT86
My friend bought a similar one for his honda si.
It fitted his because the hole on his car isn't as far back as the frs or brz
I tried it on mines, and it couldn't even reach the screw socket
The one you want is only 4 inches. it probably won't fit.
If you want a Tow hook, I recommend Cusco, even though they are pricey, they will fit!
Hentai is offline   Reply With Quote
Old 09-30-2015, 06:09 AM   #3
slicktop
Drives: 2013 Raven FRS 2JZ-GTE/V160 swapped
I just can't believe that someone in Dubai is cheaping out on something.
-slicktop
2013 Scion FRS
2JZ-GTE/V160 Swap Build Thread
slicktop is offline   Reply With Quote
Old 10-11-2015, 10:48 PM   #4
kevinchavarria
Drives: Scion FR-S
kevinchavarria is offline   Reply With Quote
Old 10-12-2015, 08:08 PM   #5
Chanpion
Drives: 13 FRS Satin
Probably won't reach out all the way for the front.
Should be okay for the rear. But seriously, don't actually use it when the time comes. I tested a slightly cheap to decent priced one before actually loading it up onto the bed and it sheared. Your trunk has an eye hook for the actual purpose, beside the spare tire. Either that, or use the hook points on the bottom of the car when you actually need to tug it out.
Chanpion is offline   Reply With Quote
Old 10-12-2015, 08:39 PM   #6
YamahaR86
JDM Vaping Stance Nation
YamahaR86's Avatar
Drives: 2013 White
I'd steer away from that if I were you if you want it just for looks still.
I've bought a bunch of stuff from China. It'll do it's job, just don't trust it. Though, the anodized stuff that comes from China WILL eventually fade into a dark brown/copper color.
YamahaR86 is offline   Reply With Quote
Old 10-12-2015, 09:26 PM   #7
gepeyo
Opal86
gepeyo's Avatar
Drives: 2013 10 Series #Opal86
The stock tow hook will probably do a much better job than the Chinese tow hooks, Cusco sounds like a much more solid idea if upgrading...
gepeyo is offline   Reply With Quote
Old 10-12-2015, 09:28 PM   #8
chaoskaze
The Fail Boat
chaoskaze's Avatar
Drives: CWP S.B.
Don't ...
But if it's just purely for looks go ahead. (color is likely gonna fade faster on those)
And make sure you grab the one from the trunk when you are actually getting tow. Or BAD THINGS WILL happen.
I know some shop there sells metal AC knobs for our car, those are good buy.
Old 10-12-2015, 09:40 PM   #9
chaoskaze
The Fail Boat
chaoskaze's Avatar
Drives: CWP S.B.
Actually that reminds me a review camera I found there that looks really sweet!
Let me look for it......
Found it http://m.aliexpress.com/item/32448373715.html
Lol anybody wanna test water??
Old 05-21-2023, 04:09 PM   #10
La5to
insta: LastoBRZ
Can't believe I have to say this but not everyone in Dubai is a millionaire.
Hello a decade later.
Old 05-21-2023, 04:44 PM   #11
soundman98
ProCrastinationConsultant
soundman98's Avatar
and despite indications otherwise, not everyone in america lives in california, nor has the same opinions as those idiots.
hello a decade later!
looking for OEM tow hook. Filipino Royale NY / NJ / CT / PA 9 06-21-2015 01:06 AM
FS: OEM tow hook ayau Exterior Parts (Aero, Lighting, Etc.) 7 12-14-2014 03:08 PM
Tow Hook TeamTFR Exterior Parts (Aero, Lighting, Etc.) 6 08-28-2014 09:15 PM
Got hook up? V1B Off-Topic Lounge [WARNING: NO POLITICS] 4 06-05-2014 03:50 PM
Tow hook Double4Free Cosmetic Modification (Interior/Exterior/Lighting) 3 08-08-2013 02:52 PM
