Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > FT86CLUB Shared Forum > Regional Forums > AUSTRALIA > Australia Classifieds
Old 09-25-2015, 12:46 AM   #1
BRZRR
Drives: Black BRZ
FS: Chiptorque XEDE Processor (Piggy back ECU)
For Sale: Chiptorque XEDE Processor (used). $600 plus shipping
Fitted to my BRZ with a custom dyno tune for a full header back exhaust and aftermarket intake. Custom map included and standard maps available from manufacturer. Plug and play. You don't need to touch the factory ECU, so good for those who want to maintain factory warranty.
Overview:
The XEDE is an interceptor style Engine Management System. It generates changes in fueling and ignition timing by changing the factory ECU’s load and crank reference input signals. It has the additional functions of two stage intercooler water spray control or potentially any other on/off or PWM function including injector drive for an additional injector. The XEDE can generate data logs and importantly can also store two separate programs which can be changed at the flick of a switch – 98 Octane or E85 fuel maps.
The XEDE Processor is a sophisticated tuning tool that gives any dyno programmer control over the engine management system without having to learn the fine nuances of each vehicle’s engine management system. The web based XMap software is available free to custom tune for accurate results.
How the XEDE Works:
The XEDE Processor integrates with an existing (usually factory) Engine Management System. The operation of the XEDE is to modify the signals from the Air flow meter / Map sensor and the Crankshaft position sensor before the factory ECU sees the signals. By changing the values of these signals, the resultant outputs from the ECU will be changed.
Benefits:
The benefits of using an XEDE over other tuning options are:
Most factory parameters are retained
Cold start functions
Idle control
Knock sensor functions
Closed loop control
Limp home operating strategies
Fan and Air Conditioner controls
Immobiliser functions
Customer Support:
Ongoing local Research & Development
Tuning email and phone support available
General Features
Base program downloaded to suit specific application
Two unique tuning map banks that allow optional setup for dual fuel map operation switched via a dash mounted switch
Up to 400 adjustment points per tuning map
Optional output for auxiliary boost injector or intercooler water spray
Unit has a fully sealed, rugged and lightweight housing
Live data display through XMap tuning software.
BRZRR is offline   Reply With Quote
ecu, tune
Our Back to Back Savings Continue with our 2015 Memorial Day Sale! FRSport.com Announcements, Contests, Giveaways 0 05-22-2015 08:10 PM
Axle back exhaust feed back requested Gruppe-s Engine, Exhaust, Transmission 10 12-10-2014 07:56 PM
18x8.5 with 235x35 on all 4 corners OR 18x8 front + 18x9.5 back 235/35 + 255/35 back KSpider Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 09-14-2013 07:06 PM
Possible trade? Nameless axle-back for Perrin Resonated Cat-back GTB/ZR-1 Engine, Exhaust, Bolt-Ons 0 03-26-2013 01:51 PM
Drove the 86GT and NC miata back to back on GT5 Hanzo FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 39 01-07-2012 12:56 PM
