Old 09-19-2015, 06:24 PM   #1
Paulo86
Paulo86's Avatar
Drives: Toyota GT86 euro version
Paulo86 GT86 black AT from France.
Hi everyone i'm paul from france and this is my Toyota GT86.
Stock options :
-Leather alcantara heated seats
-Reverse backup radar
-Rear tinted windows
Exhaust :
-TOMEI UEL header
-TOMEI Overpipe
-Fujitsubo double resonated catless Front pipe
-PERRIN 2.5" resonated Cat-back
wheels and chassis :
-Eibach pro kit springs
-Apex ARC-8 17x9 ET42 with Yokohama AD08R 245/40/17
-Goodridge braided lines, Ferodo ds2500 pads
-Zenky 50mm black lug nuts
lights :
-Full LED interior kit LedPerf
-OLM Vision+ LED licence plate light
-bi-xenon OLM fog lights with H11B 6500k Morimoto kit
-LedPerf reverse light
-High mount INTEC JAPAN third stop light
-Intec japan Tail lights
-Intec japan Headlight
-f1 style brake light in rear fog housing
-third position light in rear fog housing
-EXled usa footlight
-Tapturn flasher
-plastidip on stock turn signals
-tinted side stock markers
Interior :
-Autoradio gps Pioneer avic-f60dab
-Mtx thunderform for gt86 with Pioneer subwoofer champion series and Pioneer amp
others :
-shark Silk Blaze Helical antenna
-R-magic wing made in japan
-Grimspeed hood struts
-Blitz Touch Brain with junction box, boost sensor, oil pressure sensor and diff temp sensor
engine :
internal :
-CP Carrillo pistons 12.5:1 86.5mm
-CP Carrillo pro H rods
-King bearing XPG main bearings
-King bearing XPG rod bearings
-ARP block bolts
-ARP head bolts
-beehive GSC valve springs
-TODA oil pump
bolt ons:
-Edelbrock supercharger.
-Delicious tuning tune 98ron Flexfuel E85
-Kit Flexfuel Delicious tuning kit mk1+ DESS
-D-box Delicious Tuning for Edelbrock
-700cc DW fuel injectors
-300c DW fuel pump
-fuel injector Hard connectors Delicious Tuning
-Cusco engine mounts
-TODA idler and tensioner pulley
-dual radiator JACKSON RACING
-catch can pcv RADIUM
-fumoto oil drain valve
-Glowshift oil pressure adaptator
Transmission:
-LSD Cusco Rs 1.5 way
-5.125 cusco final drive + 29 tooth flange
-Cusco solid crush sleeve
-Cusco differential silent block insert
Paulo86 is offline   Reply With Quote
Old 10-28-2015, 06:30 AM   #2
Paulo86
Paulo86's Avatar
you can also check my youtube channel
https://www.youtube.com/c/paulo86
Old 10-28-2015, 06:38 AM   #3
Paulo86
Paulo86's Avatar
The pictures of my work on the euro version headlight
Old 10-28-2015, 06:43 AM   #4
Paulo86
Paulo86's Avatar
[ame="https://www.youtube.com/watch?v=ILvOGUBKxDQ"]Toyota GT86 full led rear lights - YouTube[/ame]
Rear lights of my gt86
Old 10-28-2015, 07:53 AM   #5
Kellhound
Drives: 2015 BRZ
First I've seen these rims on a FT-86. I need to look up how much the weigh. I have been looking into the F14's and I may like the look of your Rota's better.
Great looking car man, bravo.
Kellhound is offline   Reply With Quote
Old 10-28-2015, 09:51 AM   #6
Paulo86
Paulo86's Avatar
Thanks man
If i remember well those torque was second lightweight in this size, just behind the volk te37
Old 10-30-2015, 11:45 AM   #7
chezplatypus
chezplatypus's Avatar
Drives: 2013 FR-S, 9300 miles, auto trans
Those tail lights look surprisingly at home on a black car!
Nice car!
chezplatypus is offline   Reply With Quote
Old 11-03-2015, 05:36 PM   #8
Paulo86
Paulo86's Avatar
Nice car!
Thank you ! I think that too ! On other colors they are just strange ^^
Old 11-27-2015, 05:25 AM   #9
Paulo86
Paulo86's Avatar
my custom job on toyota 86 stock headlight.
Many thank's to www.flyryde.com !
[ame="https://www.youtube.com/watch?v=cNIGVxIA-M0"]Toyota gt86 custom headlights - YouTube[/ame]
Old 11-28-2015, 05:42 AM   #10
Paulo86
Paulo86's Avatar
[ame="https://www.youtube.com/watch?v=VTiWi3PabRo"]Toyota gt86 custom headlight - YouTube[/ame]
Old 12-30-2015, 04:44 AM   #11
Paulo86
Paulo86's Avatar
[ame="https://www.youtube.com/watch?v=JP9rRpAYfU4"]https://www.youtube.com/watch?v=JP9rRpAYfU4[/ame]
Old 12-30-2015, 09:03 PM   #12
Koj
Koj's Avatar
Drives: Toyota GT86
Hi Paul
how are you since june ?
I m happy to see you again.
I will fallow all your modification.
Koj
S/C HKSv2, HKS R Spec Manifold, Fujitsubo Authorize R Type S Catback, and more...
My Journal/Garage
Koj is offline   Reply With Quote
Old 01-08-2016, 06:38 AM   #13
Paulo86
Paulo86's Avatar
Originally Posted by Koj View Post
Hi Paul
Hey koj ! Great and you ?
Great to read you here !
A little bit more modification will follow by the end of february.
Edelbrock supercharger (with delicious tuning ron98 tune)
Olm bi xenon fog with morimoto 5500k bulbs and xb35 ballast
Grimmspeed hood dampers.
Morimoto 5500k d4s bulbs for stock bi-xenon headlight to match the color of the fogs.
After those thing i think my gt gonna be finished !
I will just need to enjoy driving it ^^
Old 01-08-2016, 06:46 AM   #14
Paulo86
Paulo86's Avatar
Some updates :
Rear lights as changed a little bit (just the fog)
I ordered 2 exled modules
-1 tpc 3a module
-1 brake light flasher module "mode 1"
The tpc allow the whelen vertex hide a way to be fix bright red when on and allow the stop wire to make the fog wire turn off and put the flashing mod on when hitting the brakes.
So it's possible with this setup to put one led bulb and make it work as fog and F1 stop.
I also put a position led bulb in the fog.
[ame="https://www.youtube.com/watch?v=jS440qTaz4w"]https://www.youtube.com/watch?v=jS440qTaz4w[/ame]
Black GT86 DeaconRoc Member's Car Journals 66 12-29-2016 05:30 PM
UK to France & Spain Kodename47 EUROPE 1 09-07-2014 09:25 AM
Fuel Help - France & Spain Kodename47 EUROPE 3 08-13-2014 05:37 PM
My Black GT86 Abdulla827 Member's Car Journals 0 01-21-2014 08:24 AM
Jeremy Clarkson and Richard Hammond Busted for Speeding in France: Lincenses Supsende Whitigir Off-Topic Lounge [WARNING: NO POLITICS] 15 11-18-2013 12:59 PM
