Old 09-17-2015, 03:46 PM   #1
nurspotts
Drives: toyota MR2 Spyder
Unhappy help BRZ head unit into FRS
I have a 2015 BRZ head unit with nav (fujitso-ten) that I am trying to put into a 2015 FRS that has the premium Pioneer unit. The XM does not work as there is no antenna for it in the FRS. But I cannot get the unit to receive AM or FM, just static. any ideas, suggestions?? tks
nurspotts is offline   Reply With Quote
Old 09-18-2015, 11:22 PM   #2
SVXdc
Radio wiring harness guru
SVXdc's Avatar
Drives: 1996 SVX L AWD
The FR-S HU sends power to the car's antenna booster amplifier via the separate single-conductor wire on the AM/FM antenna connector.
The BRZ HU sends the 12V power antenna signal out via pin #8 on the 10-pin power/speaker harness.
You'll need to rig up an adapter harness (or at least, add a jumper wire from the vacant slot on your car's 10-pin plug to the factory pin/wire on your car's AM/FM antenna plug.
SVXdc is offline   Reply With Quote
Old 09-19-2015, 04:04 PM   #3
nurspotts
David thanks. will try this and then post results
FS OEM head unit Lorico Canada Classifieds 2 02-28-2015 12:53 PM
FS: OEM BRZ Head Unit pseudo Audio/Visual, Electronics, Infotainment, NAV 0 12-22-2013 01:02 PM
BRZ Nav Head Unit Sojhinn Audio/Visual, Electronics, Infotainment, NAV 16 11-03-2013 06:02 PM
looking for a head unit for Fr-s like the Brz. enjoi23 Electronics | Audio | NAV | Infotainment 5 08-08-2012 02:51 PM
head unit in GTA excited86 Electronics | Audio | NAV | Infotainment 1 06-18-2012 07:42 PM
