Old 09-13-2015, 08:51 AM   #1
ShibaYuki
Drives: 2013 WRB Subaru BRZ Sport-tech
Installed my OFH but got codes!
I just got a P0171, P2097 and a P219A code. And I have searched it up. It says I'm running to lean, but I can smell gas. Like I've been driving a gokart. ps: running catless headers and catless FP w/ stg2 uel oct91. So I think that's the gas smell.
I tried clearing the code with the OFT, but it came back after a while.
I wouldn't know how to check for leaks, or check if my MAF is dirty, check my o2 sensors or how to fix such things.
Any help would be greatly appreciated.
ShibaYuki is offline   Reply With Quote
Old 09-13-2015, 12:17 PM   #2
FrostedFlakes
Drives: 2013 Raven FRS
What octane were you using? Did you check if your MAF is all connected properly? What about the two O2 sensors if they are on correct and not loose?
If you did the job yourself trace back the steps and make sure everything is torqued properly and any connections are put back properly.
If you took it to a shop to install then take it back and have them fix it.
FrostedFlakes is offline   Reply With Quote
Old 09-13-2015, 12:35 PM   #3
wparsons
wparsons's Avatar
Why the duplicated thread???
flickr
Old 09-13-2015, 03:39 PM   #4
ShibaYuki
91 octane shell. I did not check if my MAF is connected prolly nor the 02 sensors.
I took it to a shop. I'll have to go back and get and looked at tomorrow. I'm also getting p0137 code now. (Rear O2 sensor low voltage).
Sorry wparsons. I posted it here as well to get a general help since the Canada section wasn't get attention. But I can delete the thread if it's bothersome.
Old 09-13-2015, 05:29 PM   #5
JB86'd
JB86'd's Avatar
Drives: JAWS
I would make sure the shop plugged in your 02 sensors correctly. Standing at the front of your car outside looking at your engine bay, the 02 sensor closest to you should be the one with the gray clip, plugged in to the gray clip. The further one should be black, and plugged into the black clip. Make sure they're plugged in all the way.
Old 09-13-2015, 05:33 PM   #6
steve99
That sounds like you have a exhaust leak or issues with 02sensors
make sure both 02 sensors are plugged in
make sure black plug to black socket and grey plug to grey socket
make sure their is no O2 spacers installed especially in the front 02 sensor
grey plug is front and primary 02 sensor
generally you will need to run an M18 by 1.5 thread chaser through o2 bungs to clean thm up so o2 snsors screw in all the way to the washer without using excessive force they should screw in by hand.
its unlikey it anything to o with maf unless you have touched that area.
Old 09-13-2015, 06:29 PM   #7
steve99
If you have an air leak near o2 sensors the sensors see fresh air, so the ecu thinks engine is running lean hence lean error codes, as a result the ecu adds a crap load of fuel so you smell fuel
Old 09-13-2015, 06:32 PM   #8
ShibaYuki
I did not check yet if my O2 sensors if they're in their rightful place. I also do not have any O2 spacers.
The shop had to use some force to put in the O2 sensors in one of the bungs to be able to fit it in.
No one has touched the MAF area. So I don't think that is the problem. Right now, to me it's either an exhaust leak or o2 sensor.
Old 09-13-2015, 06:35 PM   #9
ShibaYuki
If you have an air leak near o2 sensors the sensors see fresh air so the ecu thinks engine is running lean hence lean error codes, as a result the ecu add a crap load of fuel so you smell fuel
I do smell a lot of the gas inside the cabin. As well as my fuel consumption has gone up, and I'm not even pressing the gas all the way. I just filled up last night and I'm halfway through my tank. I drove literally almost worth 45 minutes back and forth in total.
Old 09-13-2015, 07:38 PM   #10
steve99
Sounds like the shop probably stripped threads on 02 sensor or its not seated al the way in bung. You should not have to force sensors they should screw in by hand all the way then just torque them down at end they are easily damaged.
think thats likely the problem problem. leak at o2 sensor or damaged o2 sensor. best to run thread tap/chaser through header bungs to clean them up
Old 09-13-2015, 08:05 PM   #11
ShibaYuki
How will I be able to fix this problem?
And also, how will I be able to know that's where the actual leak is?
Old 09-13-2015, 10:28 PM   #12
steve99
you can log ltft and afr and commanded afr with oft
if the ltft is high like over 10% at low rpm usually indicates leak or o2 sensor issue
you can spray some soapy water arround sensors when engine cold and then start car look for bubbles.
it may be a damaged sensor but they are not cheap so best to confirm its stuffed first which can be difficult
the ring\washer on the o2 sensor should not be loose and sensor should be screwed in all the way.
you probavbly going to have to pull off header remove both o2 sensors check for damage or stripped threads, run tap\chaser through o2 bungs in header
e nstall o2 sensors ( replace if threads stripped or damaged) and header with new gaskets
or just take it to a shop to sort out.
Old 09-14-2015, 06:11 AM   #13
ShibaYuki
I have logged it w/ OFT. The AFR was usually 14:1 and goes up to 20:1 a few times. Ltft from the last I saw it was higher than 10%.
I'll rather replace the sensors and gaskets to make sure everything is new and won't cause any problems later on.
Thanks for your help Steve. you're giving me a lot of information that are helpful. I will buy the gaskets and O2 sensors and then take it to the shop. And hope to get it fixed.
Old 09-14-2015, 06:34 AM   #14
steve99
I would take it to shop first before buying parts on spec, let the shop take a look first it may be loose plug,leak or blown fuse.
you said in another thread you now have a low voltage code
afr will read 20 when your off throttle on overrun thats normal.
DTC Codes pleong Software Tuning 12 06-11-2016 01:17 AM
CEL codes (reoccurring) davidchoi Issues | Warranty | Recalls / TSB 1 12-21-2013 09:40 AM
Help - Two Codes Thrown jpit Engine, Exhaust, Transmission 3 04-20-2013 12:52 AM
Need Help - 2 codes thrown jpit Issues | Warranty | Recalls / TSB 3 04-20-2013 12:41 AM
What do these accessory codes mean? FastLap Scion FR-S / Toyota 86 GT86 General Forum 3 08-06-2012 05:56 PM
