Old 09-07-2015, 09:13 PM   #1
lupindub
Drives: Scion FR-S
What is the ACTUAL amount of oil the FRS/BRZ needs?
So it has already been proven again and again that the manual recommended 5.8 quarts is a serious overfill. So being conservative, I added only 5.3 quarts and it's STILL an overfill according to my dip stick. WTF. So does anyone actually know the right amount of oil to put in the car?
lupindub is offline   Reply With Quote
Old 09-07-2015, 09:17 PM   #2
LucidMomentum
No Money, No Problems
LucidMomentum's Avatar
Did you measure the oil level after it's been running for a while?
Old 09-07-2015, 09:19 PM   #3
aegisdrgn
aegisdrgn's Avatar
Drives: Scion FR-S 10 Series #2263
Are you sure your car is parked on level ground? I know if I park head-in it reads below the full dot, and if I park head-out it reads above the dot.
aegisdrgn is offline   Reply With Quote
Old 09-07-2015, 09:21 PM   #4
tyrantcf
Drives: '16 WRX, CBR1000RR
Do you know how to change oil?
Phantom ESC'd Build Thread (Retired):http://www.ft86club.com/forums/showthread.php?t=75293
tyrantcf is offline   Reply With Quote
The Following 3 Users Say Thank You to tyrantcf For This Useful Post:
fatalelement (09-10-2015), pushrod (09-07-2015), weedtank (09-08-2015)
Old 09-07-2015, 09:23 PM   #5
JB86'd
JB86'd's Avatar
Drives: JAWS
5.8 quarts is with the filter if it's dead empty. Are you sure you're draining the majority of the oil? Are you sure your car is perfectly even when measuring your oil? Are you measuring it 5 minutes after turning the car off from full operating temp?
I usually add 5 quarts, drive, check it, it's a little low most of the time. Add a little and it's perfectly at the top fill line on the dipstick.
Old 09-07-2015, 09:26 PM   #6
strat61caster
strat61caster's Avatar
I'm usually around 5 qts. give or take, not too fussed about the exact quantity. I've put 4.8 in and I don't think I've ever gone over 5.5 qts.
I consider the bottom line plus a little extra to be good. I don't fill to the top line, or in this car the 'top hole'.
ineedyourdiddly
Guff (09-08-2015)
Old 09-07-2015, 09:28 PM   #7
lupindub
Drives: Scion FR-S
I measured it while it was dead cold. Honestly, the ground the car on seems flat but other users have pointed out even a slight incline/decline will mess up the readings. To the naked eye, the ground seems flat but I will re-check the dip-stick at a different location tomorrow. I am pretty confident I drained most of the oil in the car.
Old 09-07-2015, 09:34 PM   #8
JB86'd
JB86'd's Avatar
Drives: JAWS
@lupindub Drive to a gas station, I think they're mostly flat near the pumps. Take a level and check if you want. Your car will be hot at least and you'll be pretty damn close to level at least.
Old 09-07-2015, 09:47 PM   #9
pushrod
Benched 86lb
pushrod's Avatar
Drives: Ultramarine FR-S
Fill it using however much it takes to satisfy the dipstick.
pushrod is offline   Reply With Quote
The Following User Says Thank You to pushrod For This Useful Post:
hmong337 (09-07-2015)
Old 09-07-2015, 10:19 PM   #10
wireman957
wireman957's Avatar
Drives: 2015 FR-S MT Steel
Just had mine changed a week ago. Replaced the filter and it took just under 6 quarts. Make sure the engine is warm before you drain it. Change the oil and filter (use a high mileage filter like the Bosch D-series with all synthetic oil) then warm it up again, and let it sit for about 15 minutes before you read the level again. Without a filter change it's going to be much closer to 5 quarts than 6.
For this oil change, my first since buying the car, I used Mobil 1. My mechanic likes Royal Purple, but I think I will probably go the Amsoil route next time. I wish I had the time and a flat place to work on my car to do it myself. Just fortunate to have a local guy I trust who charges very reasonably to work on all my family's cars. Paid him $15 to change my oil and filter when I brought him the materials.
wireman957 is offline   Reply With Quote
Old 09-08-2015, 11:55 AM   #11
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
All of my oil changes so far have been ~5.5-6 quarts out, and 6 quarts in.
I'd like to see someone disprove my statement.
-alex
Old 09-08-2015, 12:04 PM   #12
Thorpedo
The SquadWhisperer
Drives: '13 Ultramarine FR-S (STX)
5.6 seconded.
2013+14+15 Atlantic Region Motor Sports Autocross STX Champion
2013+14+15 Atlantic Region Motor Sports Overall Autocross Champion
2017 Bluenose Autosport Club Overall Rallycross Champion
Powered by Great North Performance, Jani-King Canada, and OK Tire.
Thorpedo is offline   Reply With Quote
Old 09-08-2015, 12:23 PM   #13
Guff
Now w/ over 400 womprats!
Guff's Avatar
Drives: BRZ LZR
I've put in <5qts before and 5.5+ another time. Just check your dipstick, Jimmy.
- The Ancient BRZ Sacrament
by Zaku
The Following 4 Users Say Thank You to Guff For This Useful Post:
2015firestormFRS (11-18-2017), JB86'd (09-08-2015), LucidMomentum (09-08-2015), Tcoat (09-08-2015)
Old 09-08-2015, 12:29 PM   #14
brandonblt2
The Stig's African Cousin
brandonblt2's Avatar
Drives: 2014 wrb brz
For this oil change, my first since buying the car, I used Mobile 1. My mechanic likes Royal Purple, but I think I will probably go the Amsoil route next time. I wish I had the time and a flat place to work on my car to do it myself. Just fortunate to have a local guy I trust who charges very reasonably to work on all my family's cars. Paid him $15 to change my oil and filter when I brought him the materials.
All you need to do is find a empty lot to change your oil it seriously takes about 15 to 20 minutes doing it yourself.
Instagram: brandonblt2
Build Thread: http://www.ft86club.com/forums/showt...86#post2219386
Flickr: brandonblt567
brandonblt2 is offline   Reply With Quote
Normal amount of rust for a 13? Spacemane969 Scion FR-S / Toyota 86 GT86 General Forum 23 05-30-2015 09:48 PM
Amount of Brake Fluid.... THEmailman Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 3 04-13-2013 11:46 PM
