Old 09-07-2015, 01:14 PM   #1
RandomDeception
Drives: Stock FR-S
Comparison to Stock OEM Tires
How do these tires compare in terms of grip to the Michelin Primacy HP tires?
https://www.4tires.ca/produits/view-...15-45-R17.tire
I bought my car used and these all season tires came with it, so I was wondering if they offer approximately the same amount of grip, less, or more. Can someone be able to tell either according to experience, the tread pattern, or those numerical ratings?
RandomDeception is offline   Reply With Quote
Old 09-07-2015, 01:25 PM   #2
Pat
Pat's Avatar
Drives: 2023 BRZ
I don't have any first-hand experience with that tire, but based on the description I expect it would be similar with maybe a little bit better dry performance. Generally in the same class, though.
The Following User Says Thank You to Pat For This Useful Post:
RandomDeception (09-07-2015)
Old 09-07-2015, 03:46 PM   #3
Lynxis
Lynxis's Avatar
Drives: 2013 WRB BRZ 6MT
No experience either but they're an all season 460UTQG vs the stock summer with a 240UTQG. Based on this, I actually expect these to have lower grip overall and a lower acceptable temperature range and be longer lasting. Will be fine for regular fall to spring driving but I wouldn't track on them because I imagine grip would fall off quickly as the tire is overheated.
Lynxis is offline   Reply With Quote
The Following User Says Thank You to Lynxis For This Useful Post:
Old 09-07-2015, 09:41 PM   #4
RandomDeception
Drives: Stock FR-S
Thanks! I was wondering about them because I accidentally "drifted" turning right at an intersection when I was only going at around 40 kilometres per hour with the traction control and the vehicle stability control both on. Somehow the rear end still came loose with the tires screeching and that really threw me for a loop.
Edit: 40 kilometres per hour = 25 miles per hour
Old 09-08-2015, 12:21 AM   #5
BasementN3k0
The Angry Brown Guy
BasementN3k0's Avatar
Drives: 2016 Tacoma & 2018 86 GT Black
what was your tach reading?
BasementN3k0 is offline   Reply With Quote
Old 09-08-2015, 08:24 AM   #6
RandomDeception
Drives: Stock FR-S
It was around 2000 RPM. Not high at all.
Old 09-08-2015, 12:11 PM   #7
Lynxis
Lynxis's Avatar
Correction for above, I meant to say spring to fall meaning I wouldn't use them in the winter.
Anyways, sounds like you got oversteer there? 2000RPM at 40km/h would mean you were in third. I couldn't get the rear to step out on the stockers in that situation but with the lower grip of those tires I can imagine the rear would step out if you blitzed the throttle coming out of the corner.
RandomDeception (09-08-2015)
Old 09-08-2015, 04:41 PM   #8
RandomDeception
Drives: Stock FR-S
I never consider turning off the traction control when driving on a public road, and now I will probably not even turn off the vehicle stability control with the car being this tail happy.
Old 09-08-2015, 06:11 PM   #9
Lynxis
Lynxis's Avatar
Oversteer is the nature of a front engine, rear wheel drive sports car. Yes, you should leave all of the nannies on while driving on public roads. They have definitely saved my car on multiple occasions and possibly my life too.
While I think taking a 90 degree corner at 40km/h is a bit too fast, I don't think it should be an issue even on those tires as long as you are doing it right. Just get your braking done before you enter the corner then be gentle on the throttle until the car is pointed straight again.
Old 09-08-2015, 07:37 PM   #10
RandomDeception
Drives: Stock FR-S
Haha. Don't worry, I have never turned off those controls yet and won't about to now.
Old 09-09-2015, 12:17 PM   #11
chickencornsoup
Drives: 2013
I had similiar situation before, taking a 90 degree corner with everthing on.
Stock tires aren't that safe.
chickencornsoup is offline   Reply With Quote
The Following User Says Thank You to chickencornsoup For This Useful Post:
RandomDeception (09-09-2015)
Old 09-09-2015, 12:54 PM   #12
BigFatFlip
sleep, drive, eat, repeat
BigFatFlip's Avatar
Drives: '13 BRZ, '12 Outback
Generally, "summer" and "all season" are misnomers. Summer tires, like the Primacy's, have much better dry and wet grip than All Season tires. The name "All Season" stems from the fact that it is a compromise, giving up good dry/wet weather grip for better cold weather performance. Since the OP is from "The Land of Always Winter", I guess technically, they're better of with the All Seasons
The Following User Says Thank You to BigFatFlip For This Useful Post:
Old 09-09-2015, 02:59 PM   #13
RandomDeception
Drives: Stock FR-S
Oh, I did not know that the OEM Michelin Primacy HP tires were summer tires.
I just thought they were also all season tires.
Old 09-09-2015, 11:26 PM   #14
churchx
churchx's Avatar
Drives: 2014 GT86
They are not all season (IIRC that's the reason why in some states, where cars are more often sold with all season ones, they are replaced with other tires, don't recall which ones though). They compromise on some other ground, giving up some grip for lower rolling resistance for more economy and less thread wear for longer life. That lower grip eases fun of getting rear sideways even with low stock NA power level though and which probably was the reason of selecting them as stock, normal grip summer tires even of same size will make it a bit harder to do, at least in slower speeds.
The Following User Says Thank You to churchx For This Useful Post:
RandomDeception (09-10-2015)
RightFootDown-Video: Stock Scion FRS versus Turbo Scion FRS, Street Comparison kanundrum FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 0 06-09-2015 12:47 PM
FS: 2x stock rims with stock tires $120 retrosmiths Wheels and Tires 21 04-13-2014 03:20 AM
Stay safe in snow 86ers. Don't go out with crap stock tires, only snow tires stockysnail Northwest 36 12-19-2013 01:12 PM
FS: Stock Wheels+Stock Tires+TPMS sensor Pin Flare Wheels and Tires 1 03-26-2013 11:07 AM
