Old 09-04-2015, 05:53 PM   #1
denso
Drives: 86
FFS and LC on A01G
Hi! I'm runnig a OFT A01G Stage2 Rom on my 86 and i want to raise the LC RPM. RomRaider showed that the LC RPM Delta is set to value 2000 but in real life the rpm is hold at 5500rpm. I want to raise it to 6200rpm because i got sticky tyres on. How could I realise that with RomRaider?
Second I want to enable the FFS. Flat-Foot Shift RPM Delta value is set to 0. Is it possible to set it to around 6800-7600rpm?
Greetings from germany.
denso is offline   Reply With Quote
Old 09-04-2015, 06:03 PM   #2
RustySocket
Slow Learner
RustySocket's Avatar
Drives: 15 Halo FRS
.edited
RustySocket is offline   Reply With Quote
Old 09-04-2015, 07:52 PM   #3
steve99
see the TuneTweaks link below it explains how the delta works and links in their to shivs post on editing lc\ffsparameters in romnraider
suggest you also read romraider tips link as well their is a video on romraider use
always use oft definitions with oft roms, do not use defs from romraider site
Old 09-06-2015, 08:25 AM   #4
denso
Drives: 86
Many thanks!!
OFT A01G A00G 700G ROM's with V2xx changes inserted. @wayno has done some I roms steve99 Software Tuning 23 09-10-2014 07:38 AM
