Old 09-03-2015, 10:41 AM   #1
SlammedSilly
Drives: 2015 Ultramarine FR-S
WORK EQUIPS...
Whats up guys...
was curious to know if anyone is running 19's?
i got offered a set of Work Equips.... 19x10 & 19x11.5
curious to know if they'll fit??
im not running a rocket bunny kit, just a heads up...
i will need adapters, so what is the best way to go about fitting these equips?
SlammedSilly is offline   Reply With Quote
Old 09-03-2015, 10:49 AM   #2
OkieSnuffBox
Drives: '23 BRZ Limited
Maybe posting the offset will help people give you advice on fitment.
The Following User Says Thank You to OkieSnuffBox For This Useful Post:
SlammedSilly (09-03-2015)
Old 09-03-2015, 11:00 AM   #3
Bergen23
Drives: '15 Halo FR-S
Just camber all the things. It'll fit
Bergen23 is offline   Reply With Quote
The Following 3 Users Say Thank You to Bergen23 For This Useful Post:
NyC Zn6 (09-03-2015), SlammedSilly (09-03-2015), srizzors25 (09-03-2015)
Old 09-03-2015, 11:19 AM   #4
SlammedSilly
not sure on offset... i'll probably test fit before purchase, but i wanna know if its worth the time purchasing and hoping they fit... bc if they dont... not everyone has moola to buy wheels
Old 09-03-2015, 11:27 AM   #5
8R6
8R6's Avatar
Drives: FRS
what suspension set up are you on right now? with hub adapters, the wheels will be pushed out even more (from whatever offset they already are). you will definitely need to be able to add a healthy amount of negative camber and with stretched tires to fit those wheels under stock fenders.
wheel diameter, width, and offset, tire width and height, suspension type, ride height, camber adjustability. you need to have all these info available to figure out what will fit or not.
8R6 is offline   Reply With Quote
The Following User Says Thank You to 8R6 For This Useful Post:
Old 09-03-2015, 12:10 PM   #6
SlammedSilly
ill be on BC coilovers by then, i dont plan on slamming it if i run those wheels, but a nice fitment
Old 09-03-2015, 12:14 PM   #7
SlammedSilly
tires that are currently on them, 255/30/19 & 235/35/19.... not 100% sure, id have to take a look
Old 09-03-2015, 12:20 PM   #8
Kami Speed
Kami Speed's Avatar
Drives: Scion FR-S
Send a message via AIM to Kami Speed
I am going to say at 11.5 the rear will not "fit". We do not know the offset but if someone got 11.5 inch equip it would be safe to say the offset will be at least +30 or lower. If that is the case then they wont work without extended fenders.
Kami Speed is offline   Reply With Quote
Old 09-03-2015, 12:28 PM   #9
8R6
8R6's Avatar
Drives: FRS
youre going to want at least a 2" drop after you put on the coilovers, and then push the camber in to at least -2.5 or more. itll help to get your fenders rolled too.
this is my guestimate based on a final offset of +20 all around after you have hub adapters. you'll need even more negative camber if the offset gets lower.
Old 09-03-2015, 12:33 PM   #10
SlammedSilly
what about a shit ton of camber? hah, idk im just trying to figure all this out and if its worth it. and i dont wanna be cooking through wheel bearings... i can also run a smaller tire, oi have no issue with stretching the fuck out of tires... due to the fact, they wont be daily driven on...
Old 09-03-2015, 12:36 PM   #11
SlammedSilly
the wheels will only be put on for events... i just dont want to run 19's honestly... 18's would be fine... but im the wheels are from a friend and hes giving me a really good bro price
Old 09-03-2015, 05:00 PM   #12
Kami Speed
Kami Speed's Avatar
Drives: Scion FR-S
I fully understand you want to get the wheels because you are getting a good price. But sometimes they just dont fit. Only way to get that setup to look great is to stretch tires, add around 5-8 camber depending on offset and tick the rim/tire. To give you an idea: One of our customers is running this setup:
18x9.5 +5 | 18x11.0 +11
The Following User Says Thank You to Kami Speed For This Useful Post:
jumbaco (09-03-2015)
Old 09-03-2015, 06:07 PM   #13
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Front 10" with 255 tires will fit if and only if the effective offset after spacers is somewhere around +30 to +40.
Rears won't even be close.
-alex
WORK Emotion Wheels ** Winter Promotion || Free WORK Lugs or WORK Caps ** RavSpec Wheels and Tires 18 12-10-2013 05:19 PM
XXR Twerk Equips DIM Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 9 11-14-2013 11:43 AM
Work Emotion CR Kiwami Bronze 18x8.5 +47 18x9.5 +38 (5x100) w/tires + Work lug nuts serial gixxer Wheels and Tires 41 03-29-2013 03:14 AM
WORK Equips? bigjake Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 12-21-2012 10:02 PM
