Old 06-21-2012, 07:22 PM   #1
munjah
Drives: 2002 se-r spec-v
2004 sti rims on frs/brz
hi everyone.. tried the search feature, no luck...just wondering if anyone has the 2004 sti bbs rims mounted on theyre frs/brz..im running the same setup and used the stock wheel nuts.. im wondering if thats ok..any insight would be greatly appreciated. sorry for the noobish question :s thnk you for your time!
munjah is offline   Reply With Quote
Old 06-21-2012, 07:46 PM   #2
thermobox
Drives: 16 Impreza 5dr CWP
Yep, your good. The BBS used factory style nuts that are the same as the FR-S/BRZ nuts.
thermobox is offline   Reply With Quote
Old 06-21-2012, 10:01 PM   #3
munjah
oooo thats good too hear...thank you so much! thanks for your time!
Old 06-21-2012, 11:01 PM   #4
Laika
When In Doubt...
Laika's Avatar
Drives: Slowww
I had PMed a member on here that said he had two sets of these and I was trying to see if I could buy a set off him. He explained that they would require 5mm spacers. Now that I know a little bit more I can reasonably assume that those wheels have an offset of 53mm and stock is at 48mm. A gentleman from one of the tuning companies on this forum put the stock WRX wheels on the BRZ and from what I understood the car isn't really drivable as is. The front wheel has a 1/8th inch gap between the strut.
Join the Galaxy Blue Silica BRZ registry below:
https://docs.google.com/spreadsheet/...2c&usp=sharing
Laika is offline   Reply With Quote
Old 06-22-2012, 04:30 PM   #5
BlaineWasHere
Grip>Drift
BlaineWasHere's Avatar
Drives: FRS
Don't need spacers. A few FR-S/BRZ already out there with 11/12 WRX wheels/tires which are same as 04 STi wheels.
However you could run 5mm spacers if you wanted too...
Old 06-22-2012, 04:40 PM   #6
sickmint79
Drives: bmw
unfortunately those were not as light as i was hoping when i first took a look at this
sickmint79 is offline   Reply With Quote
Old 06-22-2012, 06:18 PM   #7
munjah
hmm been driving for about a week now, so far so good.. the fit with the front shock is close..but not rubbing.. just worried about the wheel nuts if anything, but ive been re-torquing the wheel nuts down occasionally and they dont seem to have loosened at all.. lol 53 offset doesnt exactly make for a flush fit, but atleast i dont have to drive with those stock wheels anymore..
Old 06-22-2012, 06:19 PM   #8
JACK 8URT0N
Black Blood of the Earth
JACK 8URT0N's Avatar
Drives: The Porkchop Express
Here's a shitty chop i did a while back.
It's all in the reflexes.
JACK 8URT0N is offline   Reply With Quote
Old 06-22-2012, 11:35 PM   #9
NOBROWS
NOBROWS's Avatar
Drives: 2013 FIRESTORM FRS
i thought sti s where 5x114.3
2013 Firestorm Red FR-S
1993 Honda civic track car
Motivate 2 Hate Motorsports
NOBROWS is offline   Reply With Quote
Old 06-22-2012, 11:38 PM   #10
m.box.design
m.box.design's Avatar
Drives: 2013 Whiteout FRS
2004-2005 STi rims were 5x100.
Old 06-22-2012, 11:42 PM   #11
OrbitalEllipses
Drives: Attitude
Incorrect; ONLY 2004 STI BBS wheels are 5*100. Furthermore they are 17*7.5 +53 versus wider 17*8 +53 that come on later years.
That would have been me. I still don't have my car so I can't verify the spacers, but you are correct; they are 53mm offset versus the stock 48mm. Using the 1010tires calculator I figured it would reduce inboard clearance by about 11mm, which is kind of a lot. The gentleman below reports not having problems, so while it may be "tight" it might still be "right". I'll get back to you about whether or not I'm selling them, if you're still interested.
Old 06-22-2012, 11:46 PM   #12
Laika
When In Doubt...
Laika's Avatar
Drives: Slowww
I remembered it was you, I just didn't want everyone blowing up your PM box trying to buy the wheels in case I still want them
Old 06-22-2012, 11:47 PM   #13
OrbitalEllipses
Drives: Attitude
Just saying, they're classy as fuck
Old 06-23-2012, 02:54 PM   #14
dori.
Señor Member
dori.'s Avatar
Drives: white BRZ 6MT
+53.... sheeeeit
I'd rock them if they were free/cheap, otherwise...
dori. is offline   Reply With Quote
bbs, fitment, lugnuts, rims, sti
Compare to 2004 Sentra SE-R Spec V Sambosis FR-S / BRZ vs.... 3 06-12-2012 12:45 PM
Blue with 2004 STI BBS Gold wheels render JACK 8URT0N BRZ Photos, Videos, Wallpapers, Gallery Forum 10 03-29-2012 04:46 PM
Rims Visualizer dookie11 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 8 01-19-2012 11:16 PM
What rims are these? CyberFormula Other Vehicles & General Automotive Discussions 9 10-04-2011 05:27 PM
