Old 09-01-2015, 02:31 PM   #1
AppleSauce
Drives: FR-S black. Buell XB12s 25th anniv.
93 oct on 91 oft ots tune
My city got its first 93 oct pump in like decades and so i filled up woth it forgetting my tune is 91 from open flash tablet their off the shelf 91 stage 2 for headers. I remembered they have a 93 tune as well so I was planning on running a few tanks of 93 oct in it before i switch the tune to their 93 oct stage 2 tune. Is this okay? Do i need to wait a few tanks before switching it?
Also not sure if this is just the tune hut i also have noticed the AFR tends to run more rich (which i know os safer than lean) i see its almost always below 14.7:1 and especially now that its on the 93 oct which i thought would have the opposite affect.
He who shall be last shall be sideways and smiling
AppleSauce is offline   Reply With Quote
Old 09-01-2015, 02:39 PM   #2
STV3
Señor Member
STV3's Avatar
Just drive normally until you burn through your first tank of 93 and you will be fine. Even if you go WOT the car might run a little rich, but you should be fine.
STV3 is offline   Reply With Quote
The Following User Says Thank You to STV3 For This Useful Post:
AppleSauce (09-01-2015)
Old 09-01-2015, 03:37 PM   #3
mike7792
mike7792's Avatar
Drives: 2014 Scion FR-S
correct me if I'm wrong, but I believe you can run a higher octane gas with a lower octane tune. You'll only have problems if you run a higher octane tune with a lower octane gas.
mike7792 is offline   Reply With Quote
The Following User Says Thank You to mike7792 For This Useful Post:
Old 09-01-2015, 03:40 PM   #4
sstfnv
sstfnv's Avatar
the OFT 91 and 93 are identical except the timing for high RPM so you are fine to run 93 gas with 91 tune.
sstfnv is offline   Reply With Quote
The Following User Says Thank You to sstfnv For This Useful Post:
Old 09-01-2015, 04:11 PM   #5
JB86'd
JB86'd's Avatar
Drives: JAWS
If I were you I'd just keep running the 93 octane, it gives you a little insurance when driving hard or on hot days, you'll have less knock and probably better mpg too.
The Following User Says Thank You to JB86'd For This Useful Post:
Old 09-01-2015, 04:19 PM   #6
phrosty
You might get some knock at WOT if you use the 93 tune right away. Maybe run through a tank of 93 first. The power difference isn't even noticeable -- you need a dyno -- so you're not sacrificing anything if it's just your DD.
2013 Whiteout 6AT FR-S | Perrin Inlet Tube + 2.75" CAI | OpenFlash Header | P&L Catback | 4.88 Final Drive | Dialed in OFT 2.0x Stage 2 E85 | 18x8 Enkei Raijin + 225/40 Michelin Pilot Super Sport | 17x7 Stock + 215/45 Michelin X-Ice Xi-2
phrosty is offline   Reply With Quote
The Following User Says Thank You to phrosty For This Useful Post:
Old 09-01-2015, 06:37 PM   #7
Chimera
Drives: FRS
I run my car on 93 oct, on a 91 tune all the time.
The Following User Says Thank You to Chimera For This Useful Post:
Old 09-01-2015, 07:08 PM   #8
AppleSauce
The insides of my exhaust tips are atrociously black now
Old 09-01-2015, 09:31 PM   #9
steve99
The 91 you were using may have been an ethanol blend resulting is cleaner combustion, the 93 you switched to may be non ethanol hence the backer exhaust.
as @Wayno said the tunes are identical except for top end ignition timing over 5000 rpm.
oft tunes tend to be on the rich side which is safe
if you want a clean exhaust switch to e85 fuel and tune. :-)
Old 09-02-2015, 01:21 AM   #10
AppleSauce
actually they were starting to get pretty dark before i put headers on and now they are just awful. next spring im getting SC and a real tune along with it so i will hopefully not have this problem afterwards
How can you trust a tune? (tune noob) Benschneider06 Software Tuning 20 05-21-2015 12:03 PM
Drift Office Tune vs Visconti Tune mechaghost Engine, Exhaust, Transmission 109 07-03-2014 01:57 AM
Top Gear Solutions| OpenFlash Tablet Tune| Stage 1 Tune, Stage 2, Custom and E85 TopGearSolutions Engine, Exhaust, Bolt-Ons 90 04-14-2014 09:15 PM
difference between vortech tune and perrin tune? Frs32907 Forced Induction 7 12-05-2013 03:49 PM
Dynotronics and their E-Tune/ OTA tune. Ricepuddin User/Vendor/Sponsor Reviews, Feedback, Comments 5 12-24-2012 10:53 AM
