Old 08-31-2015, 10:20 AM   #1
Veejayy
Drives: VW GTI
Searched re TRD exhaust and BRZ
Still could not find exact answer. Lookin at used BRZ but want to put on TRD sways and exhaust which I assume is done at Toy dealer. Since these are roughly the same cars i would assume no problem with warranty etc?
U agree? Btw- only want TRD stuff.
Veejayy is offline   Reply With Quote
Old 08-31-2015, 10:23 AM   #2
You are correct. If installed by a Toyota dealer you should have no issue with warranty as they should fall into the "authorized service" category.
Now, that doesn't mean you won't have an issue with Subaru if they decide to play games but at least you would have some good ammo in a fight.
strat61caster (08-31-2015)
Old 08-31-2015, 01:17 PM   #3
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Warranty is not under consideration unless you are talking about warranty on TRD parts.
As a general rule, TRD parts warranty will only be applicable to the car it was originally intended for. Unless Subaru was being bought by Toyota corporate tomorrow, you will not be able to get the full TRD warranty if installed on a BRZ.
As for vehicle warranty, no one cares unless you have a legit warranty claim for something that may be affected by a performance modification installed.
-alex
The Following User Says Thank You to mav1178 For This Useful Post:
humfrz (08-31-2015)
1st to 2nd Gear Clunk (Searched, but not the same issue as the other ones) shu5892001 Issues | Warranty | Recalls / TSB 26 03-26-2015 03:23 AM
Passenger side window issue. I've searched and tried everything but no fix skygt19 Issues | Warranty | Recalls / TSB 14 11-09-2013 03:22 PM
I've searched all over, OEM mud guards color matched and painted? post_break Scion FR-S / Toyota 86 GT86 General Forum 1 09-03-2013 03:52 PM
i searched and searched _F-R-S_ DIY (Do-It-Yourself) Guides 1 11-19-2012 06:02 PM
Front Rotor Specs - Yes i searched. njccmd2002 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 11 09-03-2012 01:58 AM
