Old 08-30-2015, 03:51 AM   #1
strat61caster
strat61caster's Avatar
Door Trim Endpiece Cap Part Number?
Hey guys, so I have a terrible habit of closing the door by pushing on that plastic trim piece next to the window (pic below will make it obvious) and the end cap fell apart in my hands today. Looking at it I don't think it'll cause any problems but I'd rather not allow the elements to try and sneak into the door panel somehow.
I almost want to say it's part number 61256 in the diagram linked here:
http://parts.youngsubaru.com/a/Subar...10-605-02.html
But it's called a 'Door stabilizer' and $12 is definitely too much
http://parts.youngsubaru.com/p/Subar...1256CA000.html
Maybe I need to buy the whole plastic piece? Might be glued in from the factory? (61280A in my case) but at $80 that's a ripoff for what's wrong, guess I'm supergluing it together tomorrow, lucky I still have the part.
tl;dr use the door handle to close the door like a civilized person.
ineedyourdiddly
Old 08-30-2015, 04:03 AM   #2
humfrz
Hey guys, so I have a terrible habit.........
Oh, I'd just glue it back on.
Then make a sign to glue to the car "DO NOT USE THIS TO OPEN/CLOSE THE DOOR"
Then make another sign to remind you to read the other sign .....
Now, wasn't I a lot of help ......
humfrz
strat61caster (08-30-2015)
Old 08-30-2015, 04:30 AM   #3
strat61caster
humfrz
I'm finally good enough at remembering when I go tracking/autocrossing that I don't need post it notes/blue tape to remember to turn on the camera and turn off the traction control.
Yeah I probably do need to put a post it note next to the armrest: "Use the handle dummy"
ineedyourdiddly
humfrz (08-30-2015)
Old 08-30-2015, 05:21 AM   #4
Packofcrows
hey you, yeah you <3
Packofcrows's Avatar
Drives: 2014 37J FR-S
Id go dealer lol or gorilla glue/crazy glue.
Packofcrows is offline   Reply With Quote
Old 08-30-2015, 09:34 AM   #5
BRZnut
Drives: BRZ DGM Limited
use clear caulk! I use it for all repairs like that
The Following User Says Thank You to BRZnut For This Useful Post:
Old 08-30-2015, 02:13 PM   #6
strat61caster
41k miles, don't think this falls under 'powertrain' warranty...
I also would not be surprised if the dealership glued it back together too.
ineedyourdiddly
Old 08-30-2015, 02:55 PM   #7
humfrz
Then, touch it up with a sharpie .....
humfrz
Old 08-31-2015, 11:02 AM   #8
Sosa
[||]--(86)--[||]
Sosa's Avatar
Drives: 2015 Firestorm FR-S
That sucks! I don't know the part number but I must thank you for the post as I closed my door in the same manner. Time to find some post it notes :-)
[||•]==(86)==[•||]
Sosa is offline   Reply With Quote
The Following User Says Thank You to Sosa For This Useful Post:
strat61caster (08-31-2015)
Old 08-31-2015, 11:18 AM   #9
I broke mine trying to "fix" it. It was sticking out so I pushing on it really hard and it twisted sideways and broke just like yours. After I broke it I realized that it wasn't the issue to start with and the whole piece of window trim had simply slid forward 1/2 an inch. I glued the cap in, gave the trim a slight push back and all was good in the world again.
Old 08-31-2015, 12:03 PM   #10
strat61caster
Yes glued it yesterday. At this point I think the endpiece is part of that whole length of stripping and $80 to fix it is totally not worth it.
ineedyourdiddly
Knee Pad trim part number? TotsGT86 Issues | Warranty | Recalls / TSB 7 11-05-2014 09:49 PM
Clear plastic sheet door seal part number? nalc Cosmetic Modification (Interior/Exterior/Lighting) 0 01-08-2014 10:29 AM
Part number request for heated seat switch trim azian_advanced Cosmetic Modification (Interior/Exterior/Lighting) 1 09-14-2013 12:02 AM
Steering Wheel trim part number djliquidsteele Cosmetic Modification (Interior/Exterior/Lighting) 2 07-04-2013 01:20 PM
Door Light - After the part number for this DriftEightSix Cosmetic Modification (Interior/Exterior/Lighting) 0 07-07-2012 04:49 AM
