clunk sound while backing out of my drive way
So apparently this only happens when i back out of my drive way, it could be my tires but i'm not sure.
So basically i let the car warm up, then i put it in reverse and start pulling out. and as i turn my steering wheel, i sometimes would hear a clunk(about 70% of the time). I have stock wheels and tires and car has not been lowered. anyone else has experienced this before? Thanks guys! Problem Solved: As to my expectation, it was the spring rotating digging into the top mount. this only happens when i'm in reverse because the spring is rotating in the opposite direction, thus making the poping noise. Subaru dealer has put a rubber gasket between the spring and the top mount to see if the problem goes away. after testing for an entire weekend, there seem to be no more noise coming from the front of the vehicle when i put her into reverse and turning. Subaru dealer has agreed to change the entire strut/spring assembly if the gasket does fix the problem, thus confirming the issue. edit: it does sound a little like spring or a bushing poping. edit 2: it doesn't only happen while i back out of my drive way, although i'm 99% sure its gonna happen there every time. edit 3: Problem has been solved. Last edited by slyphen; 12-07-2015 at 05:55 PM. |
Drives: 2005 Toyota Camry
Could just simply be the front springs moving around in the strut.
hmmmm........does your driveway slant up or downhill ...... ??
The sound could be the ABS doing a self-test.... ?? Could be the limited slip differential settling in ..... ?? humfrz |
its not on a hill, but it is definitely not flat. slight slant upward. if i leave the car in neutral, it would slowly roll backward.
Power Ranger Elite
Drives: '13 WRB Sport-tech
It may not be a spring, but could be your brake pad unsticking from the rotor. Sometimes rust forms over night and you hear a pop when they separate.
will the rust be visible? because i don't see any. not closely at least, maybe i should. also it pops while i'm backing out and turning the wheel, if its the rotor, wouldn't the sound happens the moment i move?
#8 | |
Yes, usually it can be seen ..... but, sometimes you have to look closely. If the pad was "sticking" to the rotor, then breaking lose, it would make a sound right when you first move the car. If it is a spring "popping" you may consider spraying a bit of silicone spray around where the springs meet their seat. Back in the day, we would mix up a concoction of kerosene and oil and squirt the heck out of the suspension parts till they didn't squeak anymore …… ![]() humfrz |
#9 | |
yah it is very weird. i just went home for lunch and wanted to see if i can replicate the sound. this time i didn't turn the wheel as much as i used to when i backed out of my spot. I still heard the "pop" but it wasn't as loud. it sounds like a spring + rubber pop. and it happens as i get out of the drive way and as the car is turning. very strange... |
#10 | |
Power Ranger Elite
http://www.ft86club.com/forums/showthread.php?t=76006 Sent from my Nexus 5 using Tapatalk
#11 |
To isolate it:
Raise the front of the car off the ground. Turn the wheels and see if the pads are being stuck to the rotors. If not, see if noise is there when you have the car up in the air. If there is noise when you back up and turning, it simply could just be the springs having a tiny amount of play in the spring seat in the front struts. -alex |
#12 | |
#13 |
Drives: Whiteout FR-S, Evo 8 RS
I've had a clunking for quite some time. This only happens when I set off in 1st gear after the car sits for a while, and it will only happen once. I notice the same noise when I pull up the e-brake slightly under 20 mph. I wonder if its the e-brake sticking...?
#14 |
hey you, yeah you <3
Drives: 2014 37J FR-S
Its rust and depends on break shoe brand. Oem toyota does it. Im using Wagner. They squeak but dont 'pop.'
| What's this clunk sound coming from 2nd gear after letting go of the clutch ? | awhatzable | Scion FR-S / Toyota 86 GT86 General Forum | 17 | 04-30-2015 02:14 AM |
| When I was backing up.... | Mikem53 | Scion FR-S / Toyota 86 GT86 General Forum | 5 | 04-24-2014 11:47 PM |
| Clunk sound after starting car and releasing clutch | subiestyle | Issues | Warranty | Recalls / TSB | 1 | 03-14-2014 02:30 AM |
| Clunk sound with disengaging clutch up driveway | BRRRZZZ | Issues | Warranty | Recalls / TSB | 4 | 04-22-2013 08:54 AM |
| Clunk sound from rear suspension. | j-tan | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 1 | 02-05-2013 12:39 PM |
