Old 08-26-2015, 09:41 AM   #1
nickmerronesucks
Ned flanders
nickmerronesucks's Avatar
Drives: 13 BRZ, 16 Hellcat, 22 Ram 2500
Intake manifold Removal?
Has there been a DIY on this? Searched and can't find anything.. Looking to remove it to put some clamps on my evap lines. Do the injectors and fuel rails have to be removed? or can they stay attached?
updated..found instructions
Last Modified: 9-6-2013 6.4 A Doc ID: RM000000Q0U03FX
Model Year: 2014 Model: FR-S Prod Date Range: [07/2013 - ]
Title: FA20 INTAKE / EXHAUST: INTAKE MANIFOLD: REMOVAL; 2014 MY FR-S [07/2013 - ]
REMOVAL
1. CHECK FUEL PUMP OPERATION AND INSPECT FOR FUEL LEAK 2014 MY FR-S [07/2013 - ]; FA20 FUEL: FUEL SYSTEM: ON-VEHICLE INSPECTION+
2. DISCONNECT CABLE FROM NEGATIVE BATTERY TERMINAL 2014 MY FR-S [07/2013 - ]; FA20 BATTERY / CHARGING: GENERATOR: REMOVAL+
3. REMOVE AIR CLEANER CAP WITH AIR CLEANER HOSE 2014 MY FR-S [07/2013 - ]; FA20 ENGINE MECHANICAL: ENGINE ASSEMBLY: REMOVAL+
4. REMOVE THROTTLE WITH MOTOR BODY ASSEMBLY
(a) Remove the 4 bolts and the throttle with motor body assembly.
(b) Remove the gasket.
5. REMOVE INJECTOR DRIVER 2014 MY FR-S [07/2013 - ]; FA20 FUEL: INJECTOR DRIVER: REMOVAL+
6. REMOVE INJECTOR COVER (for Bank 2) 2014 MY FR-S [07/2013 - ]; FA20 FUEL: FUEL INJECTOR (for Port Injection): REMOVAL+
7. REMOVE INJECTOR COVER (for Bank 1) 2014 MY FR-S [07/2013 - ]; FA20 FUEL: FUEL INJECTOR (for Port Injection): REMOVAL+
8. DISCONNECT NO. 1 FUEL HOSE 2014 MY FR-S [07/2013 - ]; FA20 FUEL: FUEL INJECTOR (for Port Injection): REMOVAL+
9. DISCONNECT FUEL DELIVERY PIPE SUB-ASSEMBLY
(a) Remove the bolt and disconnect the fuel delivery pipe sub-assembly.
(b) Disconnect the No. 2 fuel vapor feed hose and move the fuel delivery pipe toward the front of the vehicle.
10. REMOVE NO. 1 ENGINE COVER SUB-ASSEMBLY
(a) Disengage the 3 craws and remove the No. 1 engine cover sub-assembly.
HINT:
Disengage the 3 craws in the order shown in the illustration.
11. DISCONNECT VACUUM TUBE CONNECTOR HOSE (for Manual Transmission) 2014 MY FR-S [07/2013 - ]; BRAKE SYSTEM (OTHER): BRAKE BOOSTER: REMOVAL+
12. DISCONNECT VENTILATION HOSE
(a) Disconnect the ventilation hose.
13. REMOVE INTAKE MANIFOLD
(a) Disconnect the manifold absolute pressure sensor connector.
(b) Disconnect the purge valve connector.
(c) Disengage the 5 clamps and disconnect the battery cable.
(d) Disengage the clamp and disconnect the engine wire harness.
(e) Disengage the 2 clamps and disconnect the 4 connectors.
Text in Illustration
*a
Bank 2 Side
*b
Bank 1 Side
(f) Disconnect the fuel pump connector.
(g) Remove the 6 bolts, intake manifold and 2 gaskets.
797Performance.com
nickmerronesucks is offline   Reply With Quote
Old 08-26-2015, 09:54 AM   #2
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Drives: Heavily Modified FRS
I kinda want to know this too. Maybe check around the crawford power block threads as it has to be removed to install those?
Old 08-26-2015, 09:54 AM   #3
mrk1
Drives: Sterling BRZ Ltd
Its easier to pull the ac compressor out of the way and remove the throttle body, you can then get under the manifold to clamp the lines
The Build Thread
GT28RS - eBoost2 - 3.91 Final Drive - Supra LSD
mrk1 is offline   Reply With Quote
Old 08-26-2015, 09:55 AM   #4
nickmerronesucks
Ned flanders
Im signed into my old works identifix direct hit now...gonna see if theres anything on it.
Sent from my SPH-L720T using Tapatalk
797Performance.com
Old 08-26-2015, 09:55 AM   #5
nickmerronesucks
Ned flanders
For me to remove my belt id have to remove my turbo i think.
797Performance.com
Old 08-26-2015, 10:06 AM   #6
mrk1
Even just loosen it? just need to get it off the AC pulley.
The Build Thread
Old 08-26-2015, 10:08 AM   #7
nickmerronesucks
Ned flanders
REMOVAL
HINT:
*a
Bank 2 Side
*b
Bank 1 Side
797Performance.com
Old 08-26-2015, 10:10 AM   #8
nickmerronesucks
Ned flanders
Unsure ill look into it when i get home..I know space is very tight. I am running the OFT350/SBD kit.
797Performance.com
Old 08-26-2015, 10:11 AM   #9
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Haha, seems like to much work for me to take off. I kinda want to put gold heat foil on it (and my intake) but the gain (if any lol) will not be worth that effort!
Exhaust System/Exhaust Manifold Removal and Replacement GrimmSpeed DIY (Do-It-Yourself) Guides 52 11-11-2015 09:30 PM
Intake Manifold Bu-Tang Engine, Exhaust, Transmission 29 12-06-2014 01:43 PM
Intake manifold viking Engine, Exhaust, Transmission 6 09-23-2014 11:08 PM
Oil on/around Intake Manifold Wepeel Issues | Warranty | Recalls / TSB 2 05-12-2014 11:40 PM
WTB: intake manifold carlitosway6891 Engine, Exhaust, Bolt-Ons 0 06-22-2013 02:24 PM
