Drives: 2015 Firestorm 08/05/15
Frs/to Brz Satellite xm Antenna help pls
So I picked up my 2015 Firestorm Frs Last Saturday here in Atlanta Ga. I knew they did not come with satellite radio. I paid the stealership 320. for the so called factory toyota reciver and hardware plus 300 labor total 620.00 All along I was assuming the xm antenna would be in the top shark fin antenna. Everything works as advertised with the exception of the xm antenna which they mounted on the lower part of the back glass. It looks like crap. I have spoken on email with David at 96svx to what parts are needed to change over to the Brz antenna. I am asking anybody in the Frs community for help in knowing the specific parts and or numbers I will need to put the Factory Brz antenna which I am told already comes with the sat antenna in it, However I dont know for sure and didnt want to waste 150.00 on one and it not be able to work. If anybody has done this could you point me in the right direction on what cable leads and If in fact the Brz antenna will work. I would greatly apreciate it. Thanks so much Steve
Drives: FRS
I thought the OEM was hidden in the dash above the driver side console under the shroud..
xm antenna
Chimera, I sure hope so I will check it out this weekend. Thx so much Steve
Drives: FRS
That might be the spot for the oem GPS... I know one is in there.. I didn't have either so this is 2nd or even 3rd hand knowledge. Good luck!
#5 | |
Visit my Owner's Journal where I wax philosophic on all things FR-S Post your 86 or see others in front of a(n) (in)famous landmark. What fits in your 86? Show us the "Junk In Your Trunk". |
xm antenna
Dadhawk, thx partner I will check it out this weekend. regards Steve
#7 | |
Drives: 2015 Steel FR-S
In my Impreza I had both XM and Nav mounted above the center HVAC vents, in the dash. It worked fine 99% of the time. Last edited by Mr_Hann; 08-18-2015 at 07:25 PM. Reason: grammar yo |
xm antenna
thx , I don't know what kind of space in the frs there is above the hvac but will check it out thx sir, regards Steve
Radio wiring harness guru
Drives: 1996 SVX L AWD
In BRZ models, the factory GPS antenna is on a small metal bracket fastened just above the HU. In all other Subaru models, they place the GPS antenna in a "pocket" above the instrument cluster, just below the dash. BRZ has a similar spot, but for some reason Subaru didn't use that.
In all recent Subaru models where Sirius/XM was installed by the factory, the sat radio antenna is on the roof, usually a combo AM/FM + sat unit. In models (besides BRZ) where sat radio is added by a dealer or the owner, the OEM kit includes a sat radio antenna that you stick inside the windshield, at the far upper right corner. As I mentioned to sroby via e-mail, BRZ has versions of the various antenna "feeder cords" that include separate coax cables for AM/FM and sat radio. See these diagrams: 2015 BRZ AUDIO PARTS (ANTENNA)There are alternate feeder cords for cars without sat radio (I guess BRZ models outside North America [ADDED: and some Canadian "Sport" models that did not get a sat radio-capable HU]). Those same P/Ns probably match up to Scion parts for FR-S models, and Toyota parts for GT86 models. If you want to swap in the BRZ combo rooftop antenna, you'll need to either: A) Swap in the corresponding combo feeder cords. I haven't worked out which parts you would need. B) Keep using your existing AM/FM feeder cord, and add a DIY cord for the sat radio portion. I haven't seen the bottom of the combo antenna, so I don't know what kind of connector you would need at that end of your new cord. Added: The farther north you are, the more you'll really want the sat radio antenna to be on the roof. Added2: Good pictures of the antenna's short "pigtail" cable and its plug are several posts down in this thread: DIY - 2015 OEM Sharkfin antenna retrofit
#10 | |
Drives: 2023 WRB BRZ (MT)
#11 |
That's my understanding. As a side note the guru on this info is Dave at ae64.com. I have reached out to him on other forums. He lives in the Atlanta area I live just outside Atlanta in Dallas Ga. But it nobody has had any contact. My eyes are not what they used to be. So I can solder like I used to on active duty working on F-15,s. But I found a real sharp radio tech at Best Buys here in Hiram Ga. He has soldered many of xm and sirrus radio antennas that have broken meaning the small sat antenna wire. I am going over next tues for him to splice mine into my Brz antenna that I put on my 2015 frs. Hope that might help. best regards Steve
#12 | |
#13 |
#14 |
| Using USB for satellite option | AncientCityFRS | Electronics | Audio | NAV | Infotainment | 0 | 10-14-2014 05:32 PM |
| Iphone GPS and Satellite Radio | Ayce | Electronics | Audio | NAV | Infotainment | 0 | 06-09-2014 07:17 PM |
| Satellite Radio ID Code?? | Lebby83 | BRZ First-Gen (2012+) — General Topics | 2 | 02-22-2014 04:06 PM |
| satellite radio help!!!! | ralpho | Electronics | Audio | NAV | Infotainment | 0 | 09-13-2013 03:30 PM |
| BRZ Pearl White Beat-Sonic Antenna and Perrin 2" Shorty Antenna | ericmpena | Exterior Parts (Aero, Lighting, Etc.) | 3 | 08-08-2013 04:38 PM |
