Old 08-15-2015, 12:45 AM   #1
phongtphan21
Drives: 2013 Fr-s
Wheel spacers
What do you guys think about spacera? I've read around and a lot of people said good things about them, but what are your thoughts? I'm thinking of lowering my car about an inch with TRD springs.
Sent from my SM-N910T using Tapatalk
phongtphan21 is offline   Reply With Quote
Old 08-15-2015, 07:49 AM   #2
ntron1
Sarcastic Bastard
Drives: '13 DGM BRZ, '13 Mini, 1999 Blazer
Never heard of spacera spacers.
ntron1 is offline   Reply With Quote
Old 08-15-2015, 11:07 AM   #3
Mr.Impreza
Mr.Fujitsubo
Mr.Impreza's Avatar
Drives: 2018 STI
I thought they ruined the handling and something else?
I remember I put spacers on my Subaru for 1 week and didn't like the way the car felt so took them off and sold them haha.
2018 Subaru WRX STI ~ The Weekend Car ~
2015 Toyota 86 ~ The Sold Car ~ Build Journal
OFT Stage 1 Tune Review
Mr.Impreza is offline   Reply With Quote
Old 08-15-2015, 01:05 PM   #4
JD001
JD001's Avatar
Drives: Subaru BRZ
Hi, I have Eibach spacers, 20mm front and 25mm back. Dropped circa 35mm using Eibach Sport line springs. The car looks great, the jiggly ride on standard UK spec springs has gone. As for the spacers, I haven't noticed any change in handling however only done about 400miles since the switch.
Old 08-15-2015, 03:23 PM   #5
axelo
Drives: Whiteout frs
I have b2 designs 20 and 25 ...got more tire noise from my dunlops z ... Doesn't have the same turning capability in closed spaces... There are a couple of threads around...I've got no problems at all thus far....i will take out and clean at 5,000 and rotate tires... I think the car needs the more aggressive stance with the stock wheels...for me, the compromises are worth the look they give ....with stock wheels...
axelo is offline   Reply With Quote
Old 08-15-2015, 04:11 PM   #6
JD001
JD001's Avatar
Drives: Subaru BRZ
I agree, the drop and spacers has improved the look 100%. I am now thinking of upgrading the tyres and getting the wheels painted one colour (dark grey possibly).
Old 08-15-2015, 05:21 PM   #7
GSpeed
GSpeed's Avatar
Drives: 2015 BRZ
Sandwich Spacers + Extended Lugs = Good
"Adapter" Spacers = Bad
Spacers should only be in compression, not tension.
GSpeed is offline   Reply With Quote
Old 08-15-2015, 09:39 PM   #8
Khyron686
Drives: 2011 Outlander XLS, 2013 FR-S Blue
I have 5mm front, 15mm rear spacers. It's expensive as you also need to get longer studs put in. And you need to drop the hubs in the rear to make longer studs fit. Easier to get wheels with the offset you want vs trying to make the stock wheels poke out a bit.
Khyron686 is offline   Reply With Quote
Wheel spacers MGPAX Suspension | Chassis | Brakes -- Sponsored by 949 Racing 6 06-25-2015 04:00 PM
ARP Wheel studs and 10mm hubcentric wheel spacers S1CNSTY_SUBIE Wheels and Tires 3 04-17-2015 08:31 AM
wheel spacers? rocketbunnyfrs86 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 5 12-27-2014 12:03 AM
Spacers, RS-R Springs, TPMS Sensors, Wheel Locks, Wheel Caps, Supercharged Badge DAEMANO Wheels and Tires 4 07-09-2014 01:35 AM
H&R Wheel Spacers! vividracing Wheels and Tires 3 06-19-2012 05:11 PM
