Old 08-13-2015, 10:00 PM   #1
omran
Drives: GT86 TMG CS-V3
Smile TMG & DRT race car project
hi guys,
I'm a new to the GT86/FRS world, but I'm very happy to enter it. i have learned a lot from this forum and i wish to learn more and more from the members experience.
I'm representing a team called Delta racing team (DRT) based in Qatar and we are participating in official races around the middle east. Our new challenge was to participate in the local race using 2.0L NA engine (as per the regulations) and we have chosen the GT86 for this job.
After spending a lot of time reading and searching the web, we have decided to go for the TMG CS-V3 GT86 cup car made by TMG in Germany. The car has been manufactured in the TMG workshop and was shipped directly to us. Thanks for TMG for this!
As you know, the car came with V3 specification which leaves the engine as completely stock, but modifies the handling.
the complete specs of the car is available on :
HTML Code:
http://www.toyota-motorsport.com/motorsport/images/CS-V3_Technical_Specifications_2013_car.pdf
But in brief, The car specs are as follows:
Power:
1. Engine: stock
2. Inlet & filter : stock
3. Exhaust :custom made by TMG
4. manifold : stock
Suspension:
ÖHLINS 2 way adjustable front with Camber adjustable
Rear fixed
Torsen LSD; 4,1 Ratio
O.Z. 17”x8 racing wheels
Brakes:
STD rotors Ventilated front
STD Rear Rotors solid rear
Racing pads done by TMG
Braided brake lines
TMG brake cooling duct system
harness:
FIA approved racing seat with TMG console
Steering wheel 320mm, 3-Spoke racing wheel with PTT Button
6-point racing TAKATA safety harness, HANS applicable
electronic fire extinguisher system
Full welded roll cage.
Now, After trying the car on the track in the official tests, the car felt great in handling & it is very reliable especially with the hot weather that we have here. TMG has made a really great car that could run even for 24hours race with no problems. However, its not enough to compete in this race and we need to look for more modification to be done especially on the power.
As per the race regulations, the engine should remain stock with 2.0L NA, but all other parts are free of restriction including the ECU and the inlet.
my question is, what i can do to increase the power with the same engine. i have decided to go for UEL headers with skunck 2 filter, but can i do anything more?
any suggestion? keep in mind that the car is used only for races
Also, do i have to make any ECU tune for the Headers & the filter only?
i will keep this thread for the project progress and will update it with pictures, modifications, & race results
thanks
omran
omran is offline   Reply With Quote
Old 08-14-2015, 05:35 AM   #2
omran
ok to add on the above, i started the cooperation with three main companies for helping me in modification, these are:
1. braking: (Project Mu)
- change the STD rotors and throw in SCR pure plus rotors all around
- change the pads to have H16-03 pads
This combination should give me the best performance in brakes with the STD brakes size.
2. Weight reduction: (plastics 4 performance)
lexan windows kit from P4P
3. aerodynamics: (from FT-86)
- APR Carbon Fiber Formula 3 Mirrors
- APR Carbon Fiber Rear Diffuser
- Password JDM Dry Carbon Fiber Rear Diffuser
- APR GT-250 Carbon Fiber Wing 67in
all three companies were great in their services and will post some pictures once all the installation done.
Old 08-14-2015, 09:02 AM   #3
philooo
Drives: 13' Scion FRS Track car
OMG, this is a fantastic car, I am very excited to have you on the forum and hopefully you can give us some good photo of the car once you get it.
So far I have seen very few photo of the TMG build, but it looks above any build I have seen in the USA, far above.
Do you mind me asking how much did you pay for the full setup ? I think this is an important data point for all of us who built their own car... It may actually be cheaper to get it right from the get go and pay the extra $ to TMG
Looking forward to see more of the TMG car!
As far as power the exhaust header and a tune seems to be the main thing that will bring you more power. If you have access to E85 fuel, the tune will be even more beneficial.
philooo is offline   Reply With Quote
Old 08-14-2015, 06:16 PM   #4
omran
yes it is a fantastic car indeed. TMG did a great job by modifying and making a great car.
The car costs €45,815 including German VAT including all the needed options to race.
The only thing missing is modifying the engine power which I'm welling to do now.
Will post photos of the car in different stages and will keep this thread updated.
Old 08-14-2015, 07:35 PM   #5
philooo
Seriously I think you made the right choice, after all the money I spent on my car, I would have gladly pay a few extra thousands to get a brand new car from TMG. Also resale value will be much higher if you ever want to sale it.
I think so far my car should have cost me $30k for a nice ready to race car, but with all the fucked up from TR3 Motorsports, I had to redo a bunch of stuff.
After my experience I think $50k is not bad for a brand new factory backed car.
Again, I hope you can take some really good photo of the car features, I think many of us could learn from the TMG build.
Old 08-14-2015, 07:37 PM   #6
Lonewolf
Lonewolf's Avatar
Drives: Moped
I didn't see anything in the specs about an oil cooler, so that would be a must if you are racing in a hot climate.
Also, an ecutek tune would be wise since you have an UEL header and need to extract the most power from it.
Old 08-17-2015, 04:53 AM   #7
omran
the oil cooler is fitted on the car from TMG.
ecutek is a good option as i read here, but the open flash is a great tool too? isn't it? considering the lack of tuners here in country, i have to get the maps from abroad.
Old 08-17-2015, 05:04 AM   #8
omran
here you go,, some pictures during production at TMG,,,
The Following 3 Users Say Thank You to omran For This Useful Post:
ATL BRZ (08-18-2015), Lonewolf (08-17-2015), phastafrican (08-17-2015)
Old 08-17-2015, 10:31 AM   #9
CatDaddysBBQ
Drives: '13 FR-S
Plenty know way more than I do, but if you can change out the stock headers, do that. Then get a custom tune to whatever fuel you are running and that should give you a decent power bump.
Car looks great though -
CatDaddysBBQ is offline   Reply With Quote
The Following User Says Thank You to CatDaddysBBQ For This Useful Post:
omran (08-18-2015)
Old 08-17-2015, 10:49 AM   #10
wparsons
wparsons's Avatar
I would 100% go to EcuTek (or ideally a full standalone) for a dedicated race car. I would also go with good EL headers over UEL, power gains will be better. Have a look at the ACE 4-2-1 (made 199whp on California 91 octane).
I would stick with the stock intake with a good drop in filter, definitely research intakes before buying. Lots won't make any power over stock, and some will hurt power in more places than they help.
Whatever you do, you're going to want someone knowledgeable to help with the tune. It needs to be tuned for the gas you're going to run, in the conditions you're going to be running, and done with a good safety margin since it's a race car. What works for high dyno numbers in a cool climate with good 94 octane is going to be quite different than what you need.
I would also suggest a proper diffuser and splitter. The "diffuser" on your list is purely cosmetic and will function no differently than the stock plastic. A well designed splitter and diffuser will lower drag AND increase downforce.
flickr
The Following User Says Thank You to wparsons For This Useful Post:
omran (08-18-2015)
Old 08-17-2015, 11:09 AM   #11
AZP Installs
AZP Installs's Avatar
Drives: '11 STi->'14 BRZ | '14 Touareg TDi
Send a message via AIM to AZP Installs
Very nice! In for details although the pricing IIRC is much closer to $70-90K which makes it about 3x the price of a Spec86 Cup car with similar or lower performance.
Definitely will be following you guys for sure. Maybe we can get you to start a branch of Spec86 Cup in Qatar!
-mike
AZP Installs is offline   Reply With Quote
The Following User Says Thank You to AZP Installs For This Useful Post:
omran (08-18-2015)
Old 08-17-2015, 11:50 AM   #12
Icanfaptothis86
tickle fight referee
Icanfaptothis86's Avatar
Drives: 2015 Subaru BRZ
Can you provide pics of the rear diffusers ? and am I reading this correctly there are two rear diffusers on this?
Celery man
Electrical space wizard
Icanfaptothis86 is offline   Reply With Quote
Old 08-17-2015, 01:17 PM   #13
philooo
I am very excited to see a forum member getting a TMG car...
plenty of reverse engineering for us to do !
I am curious mainly about:
- Cutoff switch wiring
- how to they attach the interior fuse box and power steering considering the roll cage is going through the stock location.
- exact routing of the fire suppression system
- driver metal 'floor mat' exact size and attachment method to the floor
- pedals look different I wonder if they are just t86 euro or something more fancy
- trunk latch mechanism, I've never seen that one before
- hood pin mechanism details
- brake duct path (if there is any).
- ... more details photo overall
Old 08-17-2015, 01:37 PM   #14
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
thanks
omran
I am guessing forced induction is out of the question. The answer you seek is the highest octane fuel the series allows and the best EcuTek tune that you can get. The header and a free flowing race exhaust with a proper tune on high octane with lots of timing are going to give the best results.
The Following 3 Users Say Thank You to King Tut For This Useful Post:
AZP Installs (08-17-2015), omran (08-18-2015), wparsons (08-18-2015)
Video - Why We Race: Testing Project FR-S at the 2012 Global Time Attack Hotchkis FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 30 05-13-2015 03:31 PM
Project Mu race pad interest CSG Mike Tracking / Autocross / HPDE / Drifting 15 11-15-2013 03:56 PM
86 to Race inaugural Moder Sports Car Race 000 Racing AUSTRALIA 4 05-23-2013 06:22 PM
No Race Track Seats in Race Car Drivers Every Day Cars..!! JohnnyNight Cosmetic Modification (Interior/Exterior/Lighting) 24 10-16-2012 04:42 PM
Toyota FT-86 to Race in VLN Race @ Nurburgring this Weekend! First Photos! Hachiroku Scion FR-S / Toyota 86 GT86 General Forum 329 10-16-2011 08:51 PM
