Old 08-05-2015, 09:37 AM   #1
gara3een
Drives: Toyota GT-86
Exclamation V Belt Snapping
Solved thanks
gara3een is offline   Reply With Quote
Old 08-05-2015, 07:43 PM   #2
humfrz
Out of curiosity (or ignorance ....) what is the V belt driving .... ??
What is driving it ….. ??
Does it have a idler pulley ... ??
humfrz
Old 08-05-2015, 09:24 PM   #3
nickmerronesucks
Ned flanders
nickmerronesucks's Avatar
Drives: 13 BRZ, 16 Hellcat, 22 Ram 2500
Is the super charger out of alignment with the rest of the pulleys on the drive system? as in that pulley sticking out further?
797Performance.com
nickmerronesucks is offline   Reply With Quote
Old 08-06-2015, 01:35 AM   #4
Fastbrew
Drives: 2014 Pearl White BRZ
I use Gates belts.
But, I don't think that's your problem.
Fastbrew is offline   Reply With Quote
Old 08-06-2015, 12:10 PM   #5
gara3een
Driving it is the Toyota Gt86 and it does have a pulley, you can see it as member fastbrew posted.
Old 08-07-2015, 08:54 AM   #6
gara3een
Originally Posted by Fastbrew View Post
I use Gates belts.
Ive contacted Gates corporation and Will order the V-belt from there and see if that solves my issue. Ive also told them about the weather conditions and everything. Hope that works
Thanks though
Old 08-08-2015, 06:25 PM   #7
gara3een
I have checked with HKS their V belt maximum size is 6k2075 & Gates have the sizes 2127 or 2140 for the 2mm width belts.
What do you think about the company Bando?
[ame="http://www.amazon.com/s/ref=nb_sb_noss?url=search-alias%3Dautomotive&field-keywords=6PK2135"]Amazon.com: 6PK2135: Automotive[/ame]
I would invest more towards the cooling part of my engine but the weird thing is my engine temperature is always moderate even when i give the car a bit of throttle but when i open the front hood it is very hot, even after leaving the car for 2 hrs; the supercharger, belt and pipes are still hot. Im confused :|,
Alternator Belt Hima Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 4 07-03-2016 06:39 AM
A/C Vent Not Snapping in..... 86Hiro Scion FR-S / Toyota 86 GT86 General Forum 30 07-15-2015 07:08 PM
SOS. Monterey area. Belt tensioner/belt The Racers Line Northern California 11 04-06-2015 02:33 PM
Is the Belt Parkway too much for the BRZ?? BRZnut NY / NJ / CT / PA 23 03-19-2013 02:40 PM
