Old 07-30-2015, 10:44 AM   #1
burdickjp
Drives: 2013 ultramarine Scion FR-S
Who's investigated FA20DIT manifold & turbo?
I was browsing ebay for a long block and came across quite a few FA20DITs. I hadn't looked into them at all and was amused by the turbocharger placement and packaging.
Who's had a chance to look at the FA20 and FA20DIT side-by-side. Would that exhaust manifold and turbo package fit in a BRZ?
burdickjp is offline   Reply With Quote
Old 07-30-2015, 12:54 PM   #2
Dream20b
Y u do dis?
iirc the manifold and turbo will not clear the ground. Not sure on that tho
Dat Hot Lava Doe
Clearly you have no clue what you are talking about. Everything you said was completely and utterly the ramblings of a babbling idiot regurgitating garbage from his mouth. Everyone here is now dumber from reading your post. Please die now.
Dream20b is offline   Reply With Quote
The Following User Says Thank You to Dream20b For This Useful Post:
burdickjp (07-30-2015)
Old 07-30-2015, 01:19 PM   #3
AVOturboworld
Drives: 2013 "AVO Orange" FR-S
The WRX and Forester FA20DIT motors sit about 4" higher in the chassis than the FA20 in the FR-S/BRZ. The turbo setup takes all of that extra 4" up. The hotside discharge is also to the opposite (drivers) side.
So we just re-engineered the concept for the BRZ/FR-S.
AVOturboworld is offline   Reply With Quote
The Following 4 Users Say Thank You to AVOturboworld For This Useful Post:
burdickjp (07-30-2015), Dream20b (07-30-2015), hmong337 (07-30-2015), Joveen (07-10-2020)
Old 07-30-2015, 03:13 PM   #4
burdickjp
Originally Posted by AVOturboworld View Post
The WRX and Forester FA20DIT motors sit about 4" higher in the chassis than the FA20 in the FR-S/BRZ. The turbo setup takes all of that extra 4" up..
That's pretty nuts. When you look at the pics on ebay it looks like everything is tight up against the engine but it's all relative. These things are mounted stupendously low in the BRZ.
Old 08-06-2015, 09:55 AM   #5
vf1rwolfleader
vf1rwolfleader's Avatar
Drives: '13 BRZ LTD
It was designed that way for superior handling lol.You probably could remove all of the undercarriage plastic to make room, but I would be a little nervous with everything exposed to the elements and debris. Mostly because of where I live in OK. People's trash and not well-maintained roads with huge asphalt chunks everywhere. I'm pretty sure the metal engine cover has saved my oil pan at least 5 times this year.
vf1rwolfleader is offline   Reply With Quote
Old 08-06-2015, 11:14 AM   #6
Gear_One_Performance
Gear_One_Performance's Avatar
Drives: 2014 BRZ SCCA STU endurance car
From what we've seen (We have both a shop BRZ and 2015 wrx) it can be done but won't be worth the time and effort. You're better off putting forced induction on the brz/frs engine.
Gear_One_Performance is offline   Reply With Quote
Old 08-06-2015, 11:47 AM   #7
burdickjp
I'm talking about the means of putting the exhaust manifold and turbo from the 2015 WRX on the BRZ. So the BRZ engine, fuel injection, and management would remain.
Sent from my XT1045 using Tapatalk
FS: FA20club EL turbo manifold cb7tuner Engine, Exhaust, Bolt-Ons 1 07-08-2014 05:17 PM
Turbo Manifold Admired Forced Induction 1 08-26-2013 01:19 AM
Turbo manifold evanmd Forced Induction 20 07-31-2013 03:39 PM
FBM Turbo Manifold Package!! FullBlown Forced Induction 23 07-29-2013 11:45 AM
WTB Turbo manifold evanmd Engine, Exhaust, Bolt-Ons 0 06-02-2013 08:02 PM
