Old 07-30-2015, 01:40 AM   #1
keonigt
Drives: 2022 BRZ
Whiteline adjustable toe arms question
Hello, I am currently in the process of purchasing new toe arms for my brz because the stock toe arms don't offer enough adjustability for my drop.
I narrowed my choices down to the whiteline adjustable toe arms and the GTspec toe arms.
I am leaning towards getting the whiteline adjustable toe arms because the GTspec toe arms are presently back ordered until late august.
I had a question,
1. Do the whiteline toe arms offer the same amount of adjustability as the GTspec toe arms?
keonigt is offline   Reply With Quote
Old 07-30-2015, 02:47 AM   #2
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
Ask them for the minimum and maximum length specs on them. Though, I don't see why either set won't offer so much adjustment range beyond what you would need. Usually that is the case with these types of adjustable arms. Unless you got some wicked long (or short) upper and lower control arms.
Intent > Content
Old 07-30-2015, 05:44 PM   #3
keonigt
Drives: 2022 BRZ
I called them and asked and they said that whiteline offers 50mm of adjustability. Is that more than enough of adjustability to fix toe for an aftermarket drop on coils?
Old 07-30-2015, 05:49 PM   #4
FT-86 SpeedFactory
FT-86 SpeedFactory's Avatar
I had a question,
I'd be very leery about what GTSpec says. They still owe us sets from October of 2014. It's always just a few more weeks, just a few more weeks.. .etc.
Whiteline arms are very good and would be the way I would go at this point.
-Jeremy
FT-86 SpeedFactory is offline   Reply With Quote
The Following User Says Thank You to FT-86 SpeedFactory For This Useful Post:
solidONE (07-30-2015)
Old 07-30-2015, 05:56 PM   #5
keonigt
Drives: 2022 BRZ
-Jeremy
Thanks for the response!
Would you happen to know if the adjustability of the whiteline is the same as gtspec? I'm worried that the whiteline toe arm will not be able to adjust to the degree that i need it to.
Old 07-30-2015, 08:44 PM   #6
solidONE
solidONE's Avatar
Why are you so concerned about the amount of adjustment? #stanced? Lol
Intent > Content
Old 07-30-2015, 09:21 PM   #7
Bergen23
Drives: '15 Halo FR-S
I have the SPC toe arms, very happy with them, and very easy to adjust
Bergen23 is offline   Reply With Quote
Old 07-31-2015, 11:57 PM   #8
keonigt
Drives: 2022 BRZ
Correct sir. I'm looking for the adjustability for the stance.
Old 08-01-2015, 12:38 AM   #9
solidONE
solidONE's Avatar
Check out these guys. They're more #stance and #drift oriented. Extremely beefy, but also beefy weight to match. I Don't know about adjustment range, but these will take the abuse of extreme alignment better than anything else on the market that I've seen.
http://www.partsshopmax.com/page.php?59
Edit: sorry I just realized they've not release their rear toe arms.. But Like I said, call the manufactures to get the max and minimum length specs or vendors that carry different brands that have on hand to take measurements. Good luck!
Intent > Content
DIY: Whiteline Rear Adjustable Toe Arms RallySport Direct DIY (Do-It-Yourself) Guides 1 07-10-2015 09:38 PM
Adjustable control arms and Toe arms zumin Brakes, Suspension, Chassis 12 07-08-2015 06:54 AM
Brand New Whiteline Sway bars 20mm adjustable front 16mm adjustable rear deedz Brakes, Suspension, Chassis 11 03-17-2015 03:29 AM
SPC Adjustable Toe Arms Johnny_MA Brakes, Suspension, Chassis 1 07-29-2014 12:55 PM
Adjustable Camber Arms vs. Whiteline Camber Bushings digital_assassin Suspension | Chassis | Brakes -- Sponsored by 949 Racing 70 06-02-2013 06:06 AM
