Old 07-26-2015, 11:20 PM   #1
Alott53
Drives: Whiteout 2014 FRS AT
Strange Noise When Parked and Off Video
A lot of fellow friends of mine have wondered what the strange noise that occurs under the car near the gas tank after hours of no use. To clear things up I have made a video of the noise and an explanation after digging around in the users manual.
[ame="https://www.youtube.com/watch?v=CqMDvXZGqYA"]FR-S / BRZ SRANGE NOISE EXPLAINATION - YouTube[/ame]
Alott53 is offline   Reply With Quote
The Following User Says Thank You to Alott53 For This Useful Post:
ethan160222 (02-11-2016)
Old 07-26-2015, 11:38 PM   #2
dnieves
Drives: FR-S 10 Series
How is it actually doing this (what are the mechanics behind the noise)?
dnieves is offline   Reply With Quote
Old 07-26-2015, 11:46 PM   #3
Alott53
I believe it's a pump located in the fuel tank that increases pressure within the tank and checks for loss in PSI but I could be wrong. There are no statements stating what mechanics are at work in the manual.
Old 07-27-2015, 06:33 AM   #4
dnieves
So if you leave the gas cap slightly loose this thing will keep going and going? Then again you'll get a CEL, interesting!
The Following User Says Thank You to dnieves For This Useful Post:
Alott53 (07-27-2015)
Old 07-27-2015, 01:12 PM   #5
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
A lot of fellow friends of mine have wondered what the strange noise that occurs under the car near the gas tank after hours of no use. To clear things up they should go read the users manual.
I fixed it for you. And could've saved you time.
-alex
The Following 3 Users Say Thank You to mav1178 For This Useful Post:
Alott53 (07-27-2015), strat61caster (07-27-2015), Tcoat (07-27-2015)
Old 07-27-2015, 06:57 PM   #6
Alott53
-alex
A lot of people don't know what to look for in terms of what it sounds like so I decided to make a video showing it.
Old 07-27-2015, 07:19 PM   #7
mav1178
mav1178's Avatar
http://techinfo.subaru.com/proxy/712...316DSTIS_2.pdf
Approximately five hours after the engine is turned off, you may hear sound
coming from under the vehicle for several minutes. This is the sound of a fuel
evaporation leakage check and, it does not indicate a malfunction.
Old 07-27-2015, 08:49 PM   #8
Alott53
Words cannot appropriately depict sound.
Old 07-27-2015, 10:12 PM   #9
Packofcrows
hey you, yeah you <3
Packofcrows's Avatar
Drives: 2014 37J FR-S
It's dubstep resonance left over from Skrillex music you been playing.
Packofcrows is offline   Reply With Quote
Old 07-27-2015, 11:57 PM   #10
mav1178
mav1178's Avatar
This is pretty much a norm on many, many new cars, including my 2014 CT200h for starters. Just because it's unique and "strange" on your car doesn't mean it is not uncommon.
It is the evap purge valve operating and is very very common across the vast majority of new cars on the road. A lot of Owner's Manuals will state this.
-alex
Old 07-28-2015, 12:06 AM   #11
BTW, it is not "self checking for leaks". It is actually purging the charcoal canister.
-alex
From the manual:
Noise from under vehicle after turning off the engine
Approximately five hours after the engine is turned off, you may hear sound coming from under the vehicle for several minutes. This is the sound of a fuel evaporation leakage check and, it does not indicate a malfunction.
Old 07-28-2015, 12:08 AM   #12
mav1178
mav1178's Avatar
From the manual:
Wrong info, my bad. It does actually purge when the car is in operation, but you just can't hear it.
The Following 2 Users Say Thank You to mav1178 For This Useful Post:
stevesnj (07-28-2015), Tcoat (07-28-2015)
Strange noise Tiliziano Issues | Warranty | Recalls / TSB 1 06-05-2015 05:20 PM
Stuttering/ticking noise while car is parked? jermyzy Issues | Warranty | Recalls / TSB 4 03-02-2014 08:35 PM
Buzzing noise from rear pass wheel area when parked pszuvela Issues | Warranty | Recalls / TSB 7 12-11-2013 01:36 AM
Strange engine noise during startup (Video inside) StOpNG0x Issues | Warranty | Recalls / TSB 2 01-29-2013 08:24 AM
Strange noise Random_Art Other Vehicles & General Automotive Discussions 15 06-03-2011 04:31 PM
