Drives: Scion FR-S
Does the FRS need 87, 89, 91, or 93 gas?
Every one is saying you need premium gas for the FRS but which one is premium? The gas station I went to says that 89 is premium.. So is 91 and 93. So which one do you exactly fill up with?
Drives: Ultramarine
91 is minimum. You can put 93 in if your heart desires
Drives: Raven Black
I use diesel.
| The Following 6 Users Say Thank You to CBR600RR For This Useful Post: | funwheeldrive (07-23-2015), jamies31 (07-23-2015), kch (07-23-2015), NWFRS (07-22-2015), SlammedSilly (07-22-2015), Ultramaroon (07-23-2015) |
Drives: 14' FRS 6MT; 16' WRX 6MT
Really depends on where you live. I know that in higher elevation states 89 is the typical 'Premium' gas so you have no option there. The car can handle 91 octane just fine but just expect to be short of some power because the car will change ignition timing to account for less compress-able fuel. Myself personally I run 93 octane from BP which is also E10. She's running fine and I've never had the crickets in this gas (Probably just a correlation and not causation but wouldn't want to mess with a good thing) so I've never changed which gas station I go to unless it's on a long road trip. Even then I strive to find a BP with 93 octane. I'll grind my teeth when I have to fill up with 91 and/or 92.
Drives: 2005 Toyota Camry
SEARCH!!!
http://www.ft86club.com/forums/showthread.php?t=7633 Sorry OP but this has been covered a million times. 91 is minimum, if they have 92,93 or 94 that will work too. Read the book
Sarcastic SOB
I use Wesson
Edit- wrong thread, I thought this was what type of oil to use. Don't use Wesson! I use naturally produced methane, man made.
#8 | |
....... yep, it's a good idea to re-read the owners manual .......![]() I would suggest that you buy your gas from a popular, name brand, top-tier gas station and punch the button on the pump that is most expensive. PS - NOT diesel ...... ![]() humfrz |
| The Following 5 Users Say Thank You to humfrz For This Useful Post: | Bergen23 (07-22-2015), meWant (07-23-2015), Packofcrows (07-22-2015), soulreapersteve (07-22-2015), Ultramaroon (07-23-2015) |
It will run just fine on 89 as well.
#10 |
Drives: Your Car
Does a bear shit in the woods?
#11 |
Does the tin man have a sheet metal c*ck?
| The Following User Says Thank You to D_Thissen For This Useful Post: | Spicer66 (07-22-2015) |
#12 |
Drives: 2013 Firestorm FRS
you can also use windex
#13 |
#FiftyShadesOfBlue
Drives: 2015 FR-S
Easiest way to put your pump gas worries to rest is to buy an OFT and tune for E85
Engine/Exhaust: OFT w/ E85 Tune | FT86SF Catted UEL | Invidia Q300 Catback
Wheels/Tires/Suspension: Avid.1 AV-20 18x8.5 +33 w/ 245/35/18 PSS | RCE Yellow Springs | Velox LCAs Cosmetic: Valenti FT86SF Special Edition Tails | Diode Dynamics Full HID/LEDs | BRZ Fender Garnishes ![]() |
| The Following User Says Thank You to Tectoniic For This Useful Post: | smg1138 (07-22-2015) |
#14 |
Drives: 2013 Raven FR-S
I've been running E85 for a couple of months and love it. Every time I take a road trip and have to switch back to 93 it bums me out. The added power of the E85 tune and JDL headers is addictive.
