Drives: '18 Camaro V6 1LE
Track weekend postmortem (tire question)
I finished a weekend at Thunderhill East and have noticed a lot of tire wear on the shoulders. Track conditions were 90+ degrees outside, 95+ toward end of the day. It's hard to tell in the picture, but it appears the tire is almost meeting the tread at the edge when there is still at least 6/32" in the middle. The material near the outer edge also seems to be very worn. I also noticed after a session that there were several patches of medium grey chunks of some material on each tire. Not sure if they were bubbles, but they are gone now.
Link to pictures on imgur Tires are Michelin PSS 225/45R17. Camber is -1 square, 0 toe in front, -.21 degrees toe in rear. In total I have used them for four track days, a few autocross events, and 5k miles driving. Cold pressure was previously set to 35 PSI, but I noticed 3mm wear past the front shoulder, so I increased front pressure to 36 PSI, which seemed to have brought wear right to the edge for this weekend. What does this wear pattern mean? Do I need to replace as soon as tire touches tread at the shoulder? What do the grey chunks on the tire indicate? |
Drives: 2013 Red BRZ
Honestly it's called.. You used your tires. Without a lot of camber this car will wear down the edges. Rotate front to back, etc.. Try to get more camber if possible.
| The Following 2 Users Say Thank You to RedBRZ80 For This Useful Post: | hpde_addict (07-20-2015), strat61caster (07-20-2015) |
That's pretty normal, with some understeer wear, and minor overheating.
Add camber |
| The Following 2 Users Say Thank You to CSG Mike For This Useful Post: | hpde_addict (07-20-2015), strat61caster (07-20-2015) |
Drives: Toyobaru FRZ
Our cars are really hard on the shoulders on performance driving. Lack of negative camber and a MacPherson strut suspension. It sucks.
I really wish they went double wishbone up front. Better static and dynamic negative camber would help even the wear a ton. |
#5 | |
I'd rather have the front suspension from an EF civic.
| TCR's weekend/track car from Australia. | TCR | Member's Car Journals | 11 | 03-22-2016 11:18 PM |
| Weekend Tire Mount & Balance | HighContrast | Northern California | 6 | 08-23-2014 07:15 PM |
| Laguna Seca Track Day Weekend 6/28 | Shoebox | Northern California | 4 | 05-12-2013 01:17 AM |
| tire swap for one weekend? | Ingen | Scion FR-S / Toyota 86 GT86 General Forum | 6 | 01-11-2013 10:00 PM |
| TiC BRZ at Putnam for it's first track weekend | Turn in Concepts | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 7 | 10-16-2012 01:50 PM |
