Old 07-19-2015, 07:26 PM   #1
RehabJeff86
RehabJeff86's Avatar
Drives: 2013 WhiteOut FR-S
For Sale: Ichiba Spacers
1. Ichiba 5x100 35mm Spacers - $80 shipped- perfect offset for front OEM rims. Used for 300 miles only.
2013 Scion FR-S whiteout
2012 Porsche Panamera S carbon grey
2008 Range Rover Sport SS black - sold
2004 BMW M3 alpine wies - sold
RehabJeff86 is offline   Reply With Quote
Old 07-19-2015, 09:17 PM   #2
YouShallKnow
Drives: Man
Send a message via ICQ to YouShallKnow Send a message via AIM to YouShallKnow Send a message via Yahoo to YouShallKnow
I'm curious about the studs on the 25 mm spacer. Aren't they normally pressed into the spacers? Why are they removed? Do they cinch right in when you torque them down and work properly?
YouShallKnow is offline   Reply With Quote
Old 07-19-2015, 11:33 PM   #3
Wyattkb
Drives: 2014 Whiteout FRS
Also curious about the studs.
Sent from my SM-G900V using Tapatalk
Wyattkb is offline   Reply With Quote
Old 07-20-2015, 12:25 AM   #4
YouShallKnow
Drives: Man
I just spun a couple studs on a spacer I was using; real son of a bitch dealing with that problem. If the lug studs are loose, you're gonna have a bad time.
Old 07-20-2015, 08:19 AM   #5
fourvalleys
Howdy!
fourvalleys's Avatar
Drives: Party ST, Classic Mini
It looks like the "back" part of the studs has a spline on it. I'm guessing the back of the spacer has the same so they slide right in? Interesting.
fourvalleys is offline   Reply With Quote
Old 07-20-2015, 02:15 PM   #6
RehabJeff86
Yes, I pressed out those studs originally came with the spacers due to I have ARP extended wheel studs hence I did not need these studs on the spacers.
Yes, you can simply lined up the spline on the studs and the back of the spacer. Gently pressed in and the slowly torquing the bolt from the other side to get these studs back in place.
Old 07-22-2015, 02:00 AM   #7
RehabJeff86
35mm spacers still available!!
Old 07-23-2015, 03:26 AM   #8
RehabJeff86
Bump
Old 08-11-2015, 01:44 PM   #9
RehabJeff86
bump
Ichiba and H&R Wheel Spacers on Sale!! Check It Out!! Mike@CZP Wheels and Tires 363 06-17-2018 03:38 AM
For Sale: Ichiba Spacers RehabJeff86 Brakes, Suspension, Chassis 4 08-11-2015 01:43 PM
FS: 2 Ichiba 15mm spacers sw20kosh Brakes, Suspension, Chassis 3 08-04-2014 01:20 PM
FS: (MN) Ichiba v2 25mm & 20mm spacers Nate. Brakes, Suspension, Chassis 2 07-25-2014 02:52 PM
Ichiba Spacers - 25mm phatpanda Wheels and Tires 1 03-19-2014 04:16 PM
