Old 07-08-2015, 02:57 PM   #1
puma
crew chief
puma's Avatar
Drives: Race car FR-S
making the car turn!!
asking the experts here, what would you do to the setup if the driver complains that the car pushes too much in the slow corner like in the hairpins.
Our car is fast in the fast curves but we cant keep up with the other two fast cars in the serie in the slow corner.
My driver is coming from a FWD so he is used to get a car that rotates really well which doesnt seem to work with this one.
It seems like the nose is too heavy for the rear, all the weight that was removed was in the back and we added a supercharger in the front which makes thing worst.
we tried a lot of different alignment, tire pressure and shock adjustment but haven't been able to nail it yet so i taught i would ask here what you guys do. One opponent with a Genesis is much faster than us in the slow corner si it is not a fwd rwd thing.
By the way, we run on extremely cheap 300 threadwear tires, don' ask, that is how the serie is made.
thanks
puma is offline   Reply With Quote
The Following User Says Thank You to puma For This Useful Post:
Fishbone (07-14-2015)
Old 07-08-2015, 03:17 PM   #2
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
My suggestion would be soften the front sway bar or stiffen the rear sway bar. It will probably affect your mid and high speed cornering as well, so you will need to adjust your aero again.
The Following 2 Users Say Thank You to King Tut For This Useful Post:
CSG Mike (07-08-2015), DAEMANO (07-09-2015)
Old 07-08-2015, 03:20 PM   #3
juliog
juliog's Avatar
Drives: 86
Videos?
juliog is offline   Reply With Quote
Old 07-08-2015, 03:24 PM   #4
Jawnathin
Drives: Toyobaru FRZ
Are you running a square or staggered tire setup?
Is the understeer on corner entry or corner exit?
Jawnathin is offline   Reply With Quote
Old 07-08-2015, 03:30 PM   #5
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
maybe you should post the chronological order of things you did so that you wouldn't get a bunch of people telling you to try something you already tried.
Old 07-08-2015, 03:46 PM   #6
puma
crew chief
puma's Avatar
right i agree, well we went from 500# springs to 400# because the last track we raced at is extremely bad and the tires have no grip what so ever. We are thinking about going stiffer in the rear but it seems counterintuive compared to what other people do on the forum.
swaybars are stock but we tried with and without a rear one and didn't help much. we tried every tire pressure from 30 to 40. We also tried to add toe out both in front and in the rear and didn't help much, i beleive in the end we were like 2mm toe out in front and 2mm toe in in the rear on each side.
We tried 2,5 deg camber up front and than 3,5 deg, a little better but still not as we want.
This is what i am thinking for now, we don't have an aftermarket LSD, i don't know if that would change something or make things worst
Old 07-08-2015, 03:47 PM   #7
puma
crew chief
puma's Avatar
yeah we didn't try to unhook the front swaybar, it rides well in fast corners so was afraid to mess it up but it might be something we could try. Otherwise we would need to get some adjustable ones and play with those.
Old 07-08-2015, 03:49 PM   #8
puma
crew chief
puma's Avatar
we are running square 245/40/17, with such low grip tires we try to use as much patch as we can, our only other option is 225/45/17.
I would say understeer is in the middle of the corner or maybe more towards exit. It only happens in hairpin or very sharp type of curves and the last track had a lot of those.
Old 07-08-2015, 03:50 PM   #9
Can't help without videos or data, and specifics on your setup...
Old 07-08-2015, 03:53 PM   #10
King Tut
NASA SpecE30 Racer
King Tut's Avatar
You definitely need adjustable ones. They are the easiest way to tune a car quickly at the track. Unhooking the rear bar should have only made it worse. In the series I run in the rear sway bar is basically the only adjustable piece we are allowed other than alignment adjustments.
Old 07-08-2015, 04:01 PM   #11
wparsons
wparsons's Avatar
You've mentioned front spring rates and camber, what about the rear?
What gear is the driver in, and what speed?
flickr
Old 07-08-2015, 04:06 PM   #12
Racecomp Engineering
More caster. (#1 thought)
Stiffer rear compression damping.
Softer front rebound.
Raise the rear of the car slightly.
I would use a rear adjustable swaybar for sure.
A better rear LSD would help as well especially if your problems are from mid-corner to exit. But are a little bit of money.
Do 1 change at a time (especially if the car is good the rest of the time like you said).
Understeer in very tight slow corners with those low-grip tires isn't too surprising but is easily fixable with a little tuning.
- Andy
Old 07-08-2015, 04:10 PM   #13
BTW if the driver is coming from a fast FWD racecar that I assume is extremely loose on entry (as those platforms should be), then there may be some driver adjustment as he adapts to a different RWD platform. It sounds like your results are still very good so I wouldn't get too drastic with changes.
- Andy
The Following 2 Users Say Thank You to Racecomp Engineering For This Useful Post:
Thrustin (07-13-2015), wparsons (07-08-2015)
Old 07-08-2015, 05:14 PM   #14
solort
Drives: Series 10 FRS
Give the car some toe out in the front and especially toe out in back and it will turn in AND rotate better. Maybe too well....
solort is offline   Reply With Quote
WTT: White delron BeatRush spin turn knob for red aluminum Cusco spin turn knob SLVRSRFR Canada Classifieds 3 11-13-2015 03:45 PM
Making turn signal your DRL with Flashback LED bulbs coachzizi Cosmetic Modification (Interior/Exterior/Lighting) 9 01-10-2014 09:54 PM
Voice Commands with new turn by turn in IOS6? jadewbj Electronics | Audio | NAV | Infotainment 0 09-21-2012 10:11 AM
