Old 07-08-2015, 09:04 AM   #1
mid_life_crisis
Drives: FR-S 10 #103 AT
Turn signal volume
This is going to sound nuts, but I need to make them louder.
My left hand blocks the left blinker from view and I quite frequently don't hear them over the stereo/road noise, so I've turned into that old man who drives for miles with his left blinker on.
Any constructive suggestions?
Old 07-08-2015, 09:57 AM   #2
Chimera
Drives: FRS
wire a small speaker to the outputs, like one from frys. probably would be super annoying.
Old 07-08-2015, 06:35 PM   #3
KenTK808
Drives: White 2014 Scion FRS
I believe the clicker for the turn signal is in the gauge cluster itself. You would have to wire an external speaker or buzzer, like mentioned above. OR tap into the wires going to to turn signals and have bigger turn signal indicators wired up on the inside of the car. Old man status
KenTK808 is offline   Reply With Quote
Old 07-08-2015, 07:44 PM   #4
Poodles
Drives: 2015 Series.Blue
The click is the sound of the flasher module working. I found my tapturn module to be a bit louder than stock, but not a whole lot more. The guy that makes the tapturn could make you a louder one if you ask...
FS: OEM Turn Signal Stalk Zagmeister Exterior Parts (Aero, Lighting, Etc.) 4 07-05-2014 10:08 AM
Brightest LED turn signal subiestyle Cosmetic Modification (Interior/Exterior/Lighting) 2 03-07-2014 11:39 AM
Turn signal question OMGreta Cosmetic Modification (Interior/Exterior/Lighting) 6 01-27-2014 02:06 PM
Anyone seen these turn signal/drl less? djliquidsteele Cosmetic Modification (Interior/Exterior/Lighting) 7 07-15-2012 03:32 AM
